I'm considering buying this router, primarily for its dual WAN failover capability. I would like it to primarily use my cable Internet gateway but be able to fail over to a cellular USB connection in the event the cable gateway goes down.
The USB 3/4G device I would like to use the the Verizon Wireless USB Modem UML295, as described here: http://www.verizonwireless.com/inter...-modem-uml295/
Could someone with this Asus router please look at the list of supported devices and tell me if this one is included? Thanks in advance.
