Question regarding load blancing dual WAN
Stuart Turrell
Hi all,
I have started to using the load balancing dual- wan feature on my AC68U router.
I was using fail over but my 2 WAN's are similar speeds now.
I have setup a few rules for certain local IP addresses to be using particular WAN's (Ethernet LAN 1) for their connections.
One question regarding this.
If the WAN (Ethernet LAN 1) went down that those IP's are assigned too, will those local IP's stop communicating with the internet, or will they start to use the other WAN (WAN port) until the (WAN Ethenet LAN 1) comes back up?
That seems clear to me, hope you understand that ok.
Many thanks
Stuart
