So I am currently using an my very old RT-AC68U as I went back to it because my RT-AC86U failed well over a year ago.
The main reason I was using the RT-AC86U was OpenVPN client performance, as I had my VPN service running through the Router when I wanted to access geo-restricted streaming content on some of my devices that don't support the installation of a VPN client directly on them.
The OpenVPN performance is abysmal on the AC68U so I don't currently run in through the Router.
Anyway, I've been looking at AX Routers the past few days and have no idea what I should be looking at. I've looked at the RT-AX88U, RT-AX86U, RT-AX86U Pro, but these are out of my price range. I read that the RT-AX88U Pro is good too, but it doesn't look like you can buy that in Australia (I can only find the older RT-AX88U for sale here).
I then looked at mid-range models such as the RT-AX68U and RT-AX58U (not sure if these would have good enough performance via OpenVPN?)? Are any of these mid-range models worth looking at?
I've read about features such as VPN Fusion (not sure if the mid-range models support this, and are any of the mid-range models worth looking at?)
I think my paid for VPN service does support Wireguard through the Router, so maybe that would be a better option? Not sure what speeds these newer AX model support via OpenVPN and Wireguard. I'd only need between 100-200Mbps I'd say.
I was also wanted to ask, are the AC models going to be supported much longer?
Also, I read about AsusWRT 5.0. Which models would be supporting this and is it going to be a worthwhile upgrade, as in, should I be looking at routers that support it?
