HELLO_wORLD
I’m working on the next version that will have some cool stuff.
Better rules for iptables, allowing logging.
Check for any available newer version. Maybe an upgrade command.
Also, while trying logging, I found that this is really blocking a lot attempts to connect either to the router or my NAS from blacklisted IPs. So this script is really useful in protecting router and local network:
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=46.105.132.32 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=40202 DPT=9200 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=172.16.255.254 DST=224.0.0.1 LEN=28 TOS=0x10 PREC=0x80 TTL=1 ID=15699 PROTO=2 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=10667 PROTO=TCP SPT=45425 DPT=38398 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=193.32.163.112 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=240 ID=32504 PROTO=TCP SPT=58431 DPT=3381 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=46.105.132.32 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=43161 DPT=873 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=61975 PROTO=TCP SPT=45425 DPT=37674 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=142.93.211.52 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=237 ID=6539 PROTO=TCP SPT=46682 DPT=2364 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=190.255.4.26 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=240 ID=2753 PROTO=TCP SPT=45797 DPT=1433 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=111.56.44.147 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=242 ID=5509 PROTO=TCP SPT=47760 DPT=1433 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=50031 PROTO=TCP SPT=45425 DPT=883 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=3931 PROTO=TCP SPT=45425 DPT=3598 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=87.251.74.241 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=245 ID=32134 PROTO=TCP SPT=51973 DPT=756 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=172.16.255.254 DST=224.0.0.1 LEN=28 TOS=0x10 PREC=0x80 TTL=1 ID=15701 PROTO=2 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=104.206.128.70 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=241 ID=30700 PROTO=TCP SPT=50057 DPT=5432 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=6516 PROTO=TCP SPT=45425 DPT=58572 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=87.251.74.18 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x80 TTL=245 ID=11046 PROTO=TCP SPT=51205 DPT=5001 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x2
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=26830 PROTO=TCP SPT=45425 DPT=52461 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=185.176.27.2 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=246 ID=31650 PROTO=TCP SPT=8080 DPT=8683 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN= OUT=brwan SRC=192.168.1.2 DST=192.168.1.255 LEN=242 TOS=0x00 PREC=0x00 TTL=64 ID=44813 DF PROTO=UDP SPT=138 DPT=138 LEN=222
[firewall-blocklist] IN= OUT=brwan SRC=192.168.1.2 DST=192.168.1.255 LEN=235 TOS=0x00 PREC=0x00 TTL=64 ID=10105 DF PROTO=UDP SPT=138 DPT=138 LEN=215
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=194.26.29.212 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=242 ID=54638 PROTO=TCP SPT=58013 DPT=3215 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=156.96.119.148 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=245 ID=36922 DF PROTO=TCP SPT=18 DPT=3201 WINDOW=512 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=185.156.73.60 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=248 ID=388 PROTO=TCP SPT=47677 DPT=33896 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=185.176.27.246 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=246 ID=8037 PROTO=TCP SPT=58587 DPT=54249 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=156.96.119.148 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=245 ID=36922 DF PROTO=TCP SPT=5 DPT=8092 WINDOW=512 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=19243 PROTO=TCP SPT=45425 DPT=28605 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=198.98.62.183 DST=192.168.1.2 LEN=121 TOS=0x00 PREC=0x00 TTL=243 ID=54321 PROTO=UDP SPT=49117 DPT=1900 LEN=101 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=172.16.255.254 DST=224.0.0.1 LEN=28 TOS=0x10 PREC=0x80 TTL=1 ID=15703 PROTO=2 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=194.61.27.240 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=239 ID=39339 PROTO=TCP SPT=47895 DPT=5445 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=8237 PROTO=TCP SPT=45425 DPT=590 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=60.190.96.235 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=238 ID=59389 PROTO=TCP SPT=43452 DPT=28515 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=185.176.27.2 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=246 ID=42828 PROTO=TCP SPT=8080 DPT=8879 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=172.16.255.254 DST=224.0.0.1 LEN=28 TOS=0x10 PREC=0x80 TTL=1 ID=15705 PROTO=2 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=194.26.29.212 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=242 ID=54066 PROTO=TCP SPT=58013 DPT=7385 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=92.63.196.3 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=243 ID=60625 PROTO=TCP SPT=56438 DPT=9789 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=38571 PROTO=TCP SPT=45425 DPT=5096 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=94.102.56.181 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=248 ID=31650 PROTO=TCP SPT=47562 DPT=9508 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=111.229.172.178 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=237 ID=25531 PROTO=TCP SPT=56070 DPT=7384 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=45.134.179.50 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=244 ID=49338 PROTO=TCP SPT=45425 DPT=16796 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=198.108.67.83 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=34 ID=1252 PROTO=TCP SPT=21362 DPT=12301 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=170.130.187.10 DST=192.168.1.2 LEN=71 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=UDP SPT=64716 DPT=161 LEN=51 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=92.63.196.3 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=243 ID=1504 PROTO=TCP SPT=56438 DPT=9889 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
[firewall-blocklist] IN=brwan OUT= MAC=[UNDISCLOSED] SRC=194.26.29.114 DST=192.168.1.2 LEN=44 TOS=0x00 PREC=0x00 TTL=242 ID=34935 PROTO=TCP SPT=52196 DPT=5463 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x10
