I was blocked when i wrote the data from posting.
this was the output
Code:Linux R9000 3.10.20-al-5.0-ga_na #1 SMP Thu Apr 23 11:58:01 UTC 2020 armv7l unknown
Perfect, thank you!Edit haha I should read your post more closley![]()
Ok, so the next release will offer a install script able to install iprange on R9000.Perfect, thank you!![]()
wget https://voxel-firmware.com/Downloads/iprange_1.0.4-1_r9000.ipk
/bin/opkg install iprange_1.0.4-1_r9000.ipk
Status:
- firewall-blocklist version: v3.2.2
- iprange is installed: iprange 1.0.4
iprange: Ignoring text after hostname 'Members' on line 1: ':
iprange: DNS: 'Members' failed permanently: Name or service not known
- Firewall blocklist is set and active.
- Filtering 620017030 IP adresses.
- Logging is on.
Man... I dont find the words. Thank you very much this treatment is more than anyone can ask for and with no claim of counter performance. Just pure good will. Its rare in this world but its here. Thank you!
Code:Status: - firewall-blocklist version: v3.2.2 - iprange is installed: iprange 1.0.4 iprange: Ignoring text after hostname 'Members' on line 1: ': iprange: DNS: 'Members' failed permanently: Name or service not known - Firewall blocklist is set and active. - Filtering 620017030 IP adresses. - Logging is on.
Info:
- The script is properly installed.
- firewall-blocklist version: v3.2.3
- This is the last version.
Status:
- Filtering 620169848 IP adresses.
- Logging is off.
After using the blocklist for some time now. I just want to report it is working very good! I again want to thank you for sharing it. It is a install and forget about thing because it works so good. But its a delight to know that under the hood your work is constantly making my home safer. Thank you @HELLO_wORLD .
Welcome To SNBForums
