[R7800, R9000 & probably others] Blocklist based Firewall addon
Yes, by all means! The more the merrier!
@kamoj Do you want me to test these commands?
About the entware i think the problem is that I dont know what the problem is... But my goal has been to get iprange for this blocklist firewall.
  • Like
Reactions: KW.
Command 1
find / -name tty
 /dev/tty
 /overlay/opt/bin/tty
    /overlay/hipplay/usr/bin/tty
 /proc/tty
find: /proc/5126/task/5126/fdinfo/5: No such file or directory
 /rom/dev/tty
 /sys/devices/soc.0/fd883000.uart0/tty
    /sys/devices/soc.0/fd884000.uart1/tty
 /sys/devices/virtual/tty
   /sys/devices/virtual/tty/tty
  /sys/devices/platform/serial8250/tty
/sys/class/tty
    /sys/class/tty/tty
Command 2
find / -name stty
 /overlay/opt/bin/stty
 /overlay/hipplay/bin/stty
  find: /proc/32230: No such file or directory
You can remove your USB devices and reboot without entware?
Yes, I was thinking of doing that... Just can’t disrupt internet now... Maybe tomorrow morning.
root@HERMES:~$ find / -name tty
/dev/tty
/proc/tty
/sys/devices/platform/msm_serial_hsl.1/tty
/sys/class/tty
/sys/class/tty/tty
/tmp/mnt/sda1/entware/bin/tty
root@HERMES:~$ find / -name stty
/tmp/mnt/sda1/entware/bin/stty
root@HERMES:~$
  • Like
Reactions: KW.
Ok @KW. , last 2 tries:
echo -n "say y: "; echo "answer: $(head -c1 /dev/tty)"
And
echo -n "say y: "; A=$(dd ibs=1 count=1 2>/dev/null); echo -e "\nanswer: $A"
If it does not work, I will disconnect Entware tomorrow on my router (and hopefully have exact same environment than you have for testing) and/or wait for @kamoj ’s solution once he’s back home.
Here it is. Dont worry about throwing out commands you want to try. I like to play with the big guys:)
Command 1
say y: y
answer:
Command 2
 say y: y
 answer:
 root@R9000:/$ y
  /bin/ash: y: not found
Thank you for calling me a big guy, I’m not at the level of @kamoj or the ultimate @Voxel .
As you guessed, none of those are working. I give up for today.
Have a good Sunday :)
Command 1
say y: y
answer:
Command 2
 say y: y
 answer:
 root@R9000:/$ y
Ok, back and found it.
Apart from this there is also a trick involving sed and tty... ;)
I don't think you need any instruction, so here is my current solution (one of many):
Q="Do you want to uninstall the kamoj add-on? "; echo -n "$Q"
ANSWER="$(i=0;while [ $i -lt 2 ];do i=$((i+1));read -p "" yn </dev/tty;[ -n "$yn" ] && echo -n "$yn" && break;done)"
echo "$ANSWER"
Ah! Trap the stdin inside a while loop so ash does not receive it as a command, smart!
Thank you @kamoj
So, @KW. : this should work:
echo -n "say y: "; case "$(i=0;while [ $i -lt 2 ];do i=$((i+1));read -p "" yn </dev/tty;[ -n "$yn" ] && echo "$yn" && break;done)" in Y|y|yes|Yes|YES) echo 'answer is YES';; *) echo 'answer is NO';; esac
And I will be able to update my script (tomorrow) to fix the asking yes or no bug while trying to upgrade (and fix that in install.sh as it asks a question too).
echo "$ANSWER"
Nah Im done testing for today... haha sorry just kidding Im never done. I think something happened. You guys are so impressive! I love the comment "Ah! Trap the stdin inside a while loop so ash does not receive it as a command, smart!" It is so far away from my understanding but breath so much knowledge.
Fantastic! Here is my report of the update.
Befor the update running the clean command:
/opt/bolemo/scripts/firewall-blocklist clean
 iptables v1.4.21: mark: bad mark value for option "--mark", or out of range.
Try `iptables -h' or 'iptables --help' for more information.
grep: xregcomp: Unmatched [ or [^
 root@R9000:/$
After installation:
Info:
 - The script is properly installed.
- firewall-blocklist version: v3.2.2
  - This is the last version.
- iprange is not installed.
rm -r fbl command didnt work
rm -r fbl
rm: descend into directory 'fbl'? y
root@R9000:/tmp/mnt/sdb1$
Status:
Status:
- Firewall blocklist is set and active.
  - Filtering 619977398 IP adresses.
 Logging is off.
/opt/bolemo/scripts/firewall-blocklist update -v
firewall-blocklist v3.2.2 - Verbose mode
Initializing...
 - /opt/scripts/firewall-start.sh was edited and is now ok.
 Updating blocklist from sources...
 - Downloading lists defined in /opt/bolemo/etc/firewall-blocklist.sources
1) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level1.netset
 -      100%[===================>]  38.90K  --.-KB/s    in 0.004s
2) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level2.netset
-     100%[===================>] 273.25K  --.-KB/s    in 0.04s
3) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level3.netset  -
100%[===================>] 258.12K  --.-KB/s    in 0.03s
4) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/iblocklist_ciarmy_malicious.netset
100%[===================>] 202.70K  --.-KB/s    in 0.02s
5) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/malwaredomainlist.ipset                            -
  100%[===================>]  14.49K  --.-KB/s    in 0.002s                                                      - iprange not installed, passing optimization and reduction process.
  - Removing duplicates...
 - Done.
  Building ipset blocklist (44959 entries blocking 619977398 ips)...
  - Created blocklist.
- Done.
Restarting firewall...
- Built-in firewall restarted.
  Status:
- Logging is off.
 Detailed status:
- /opt/scripts/firewall-start.sh exists with correct settings.
- Actual router time: Sun May  3 18:18:42 UTC 2020
 - Blocklist generation time: Sun May  3 18:18:42 UTC 2020
- Router firewall was last started Sun May  3 18:18:43 UTC 2020:
  ipset blocklist was already loaded and was kept.
 blocklist rules were added to iptables.
- iptables rules are set:
iptables -N FwBl_DROP
  iptables -A INPUT -i brwan -m set --match-set FwBl_BL src -j FwBl_DROP
iptables -A FORWARD -i brwan -m set --match-set FwBl_BL src -j FwBl_DROP
iptables -A FORWARD -o brwan -m set --match-set FwBl_BL dst -j FwBl_DROP
  iptables -A OUTPUT -o brwan -m set --match-set FwBl_BL dst -j FwBl_DROP
iptables -A FwBl_DROP -j DROP
- Logging is inactive.
- ipset filter (blocklist) is set:
 Type: hash:net
 Revision: 6
 Header: family inet hashsize 32768 maxelem 65536
  Size in memory: 1396788
  References: 4
  Number of entries: 44959
 - ipset bypass (whitelist) is not set.
 root@R9000:/$
For info, this iptables error you get is not coming for the script. Apparently, native NG setups are throwing some errors (likely to be without incidence because all routers sold are concerned).
After installation:
Info:
rm -r fbl
Interesting. Did it do that before?
Anyway, not major. You can remove doing exactly:
cd /mnt/optware
(or whatever is the root of your USB)
Then
rm -rf fbl
I will improve the install script to delete the directory by itself. The simpler to install, the better.
Status:
Status:
 Logging is off.
Initializing...
 - Done.
- Done.
  Status:
- Logging is off.
 Detailed status:
 Type: hash:net
 Revision: 6
  References: 4
Good evening :)
The blocklist works very fine and as before I notice no drawbacks on my networks performance. All i got with your script is a safer network:) Now on my wish list is the iprange. I hope it is possible to get in the script for r9000 sometime in the future.
Your script is here to stay thank you allot for sharing it!
Thank you!
I am glad this is useful to other people :)
For iprange on R9000 (without Entware), I will need to ask @Voxel as he has the compiling environment.
Entware was easy to install for me following Voxel’s readme, but maybe it’s a little different for R9000.
@KW. interested in iprange for R9000?
Can you run that for me and report the output:
/bin/uname -p
That is to update my install script to recognize when it is launched from a R9000 and offer to install iprange :)
@Voxel kindly compiled it.
