The question asked was what is best.
Exactly. The best way to write 1KB data is to plug the USB in and forget about it.
Storing traffic data as per @L&LD:
- enable custom scripts support
- install AMTM script
- plug in the USB
- format the USB with ext4, with journaling
- reboot
- select path for traffic data
Get as a bonus:
- erase all the data on USB during formatting (see options)
- make this USB incompatible with Windows PC (see options)
- prevent the built-in Asuswrt Health Scanner to check this USB (see options)
Options:
- backup the data before formatting, if you need it
- get a Linux PC to read the data, or converter software for Windows, or activate Samba
- use another script in AMTM to perform health check at boot
Storing traffic data as per @Val D.:
- plug in the USB as it is, FAT/FAT32/NTFS
- select the path for traffic data
Get as a bonus:
- save time
- maintain USB compatibility
- keep the existing data on that USB
- get it checked by the built-in Asuswrt Health Scanner
- use the USB for something else without the need to reformat and erase it
I'ts up to
@htismaqe to decide what is "best" in this case.
WTFast in action again...
Some smileys:
What's the best FS to use for USB if all I'm doing is storing traffic monitoring files?
