Trying to decide whether I should get something like this (doesn't ship to Australia)
http://www.amazon.com/dp/B000JLF4FG/?tag=snbforums-20
OR....
A discrete Gbit switch which fits snugly into the 19" rack (approx. 6U) with swing door that I'll be installing.
AFAICT I'll need 6 Ethernet ports all up:
2x WAN ports (1 for our Cable MODEM & 1 for our 4G MODEM/Antenna)
3x LAN ports for 3 runs to 2 locations downstairs (1 of those runs/locations is for the household's main WiFi AP)
1x LAN port for 1 run to 1 location upstairs
With 8 ports in total, that still leaves us with 2 ports, should we decide to do some runs to other locations.
I'm not sure if one can get top-notch/quality discrete Gbit switches with as little as four ports.
I'm not even sure if four's enough, maybe it's safer to have 6 or 8, bringing the total up to 10 or 12 ports?
Then again, I'm quite sure 8 in total should suffice for the foreseeable future...
I guess it depends on if I could be using that sole PCIe slot for something that's more important?
I don't need a RAID controller, as this build won't be my primary NAS or Local-host/Server.
I'm not sure what else one might want to put in that PCIe slot, other than an Ethernet card???
I wouldn't want to put a Graphics or Sound card in there etc. etc...
Also, is 10Gbe more reasonable nowadays, or is it still way too exorbitant to justify getting a 10Gbe 4-port card or discrete switch? I know it's massive overkill, but I'll be shuttling loads of data quite regularly between my NAS in the storage room, & my HEPC/PVR/kitchen-sink at the other end of the house. I doubt Gbit-only will be an issue any time soon, especially since I'll have two Ethernet ports at that location so I can do dual Gbit if/when needed, but if 10Gbe's not exorbitant -then why not make the jump!?!
OR....
