solstyce
I have observed a need to wait approx 5 mins after adjusting QOS settings, before running the next test.
I'm pretty sure that means the manual bandwidth settings.
Yes, the FreshJRQoS script has a built-in 5 minute delay before it enables its rules. This is to give the default Asus QoS rules to be fully defined and live before the FreshJRQoS script modifies them. You can see this in the system log.
BTW, thanks for the tip on using your own ping test to check for bufferbloat. I have pingplotter installed so presumably I could use that for this to doublecheck the results I'm seeing from DSLReports speed test.
