I would love to hear how it goes. I am also trying to add a domain to Client1 and I am not very good with all these scripts... thxthank you both
ill do some tests tonight and come back if i require more help
/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/Xentrk/x3mRouting/master/install_x3mRouting.sh" -o "/jffs/scripts/install_x3mRouting.sh" && chmod 755 /jffs/scripts/install_x3mRouting.sh && sh /jffs/scripts/install_x3mRouting.sh
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# . load_DNSMASQ_ipset_iface.sh 1 US_vpn1 ifconfig.io
(-sh): 3833 Starting Script Execution
(-sh): 3833 IPSET created: US_vpn1 hash:net family inet hashsize 1024 maxelem 65536
(-sh): 3833 CRON schedule created: #US_vpn1# '0 2 * * * ipset save US_vpn1'
(-sh): 3833 Selective Routing Rule via VPN Client 1 created for US_vpn1 (TAG fwmark 0x1000/0x1000)
(-sh): 3833 Completed Script Execution
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# iptables -nvL PREROUTING -t mangle --line
Chain PREROUTING (policy ACCEPT 9794 packets, 12M bytes)
num pkts bytes target prot opt in out source destination
1 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set US_vpn1 dst MARK or 0x1000
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# ip rule
0: from all lookup local
9993: from all fwmark 0x4000/0x4000 lookup ovpnc3
9995: from all fwmark 0x1000/0x1000 lookup ovpnc1
32766: from all lookup main
32767: from all lookup default
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# ipset -L US_vpn1
Type: hash:net
Revision: 6
Header: family inet hashsize 1024 maxelem 65536
Size in memory: 316
References: 1
Number of entries: 0
Members:
strict-order
dhcp-option=lan,42,10.0.0.1 # ntpMerlin
server=/pool.ntp.org/1.1.1.1
ipset=/pandora.com/US_vpn1
ipset=/ifconfig.io/US_vpn1
Thanks for using the script. The problem looks like the IPSET list is not getting populated. I used pandora to duplicate your issue:hi,
i just cant get this to work.
I have my openvpn client running on client 1. Accept DNS Configuration is STRICT
i installed the script
Code:/usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/Xentrk/x3mRouting/master/install_x3mRouting.sh" -o "/jffs/scripts/install_x3mRouting.sh" && chmod 755 /jffs/scripts/install_x3mRouting.sh && sh /jffs/scripts/install_x3mRouting.sh
and ran option 3
then, i ran the following command hoping that ifconfig.io loads through my vpn client and not my wan
Code:admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# . load_DNSMASQ_ipset_iface.sh 1 US_vpn1 ifconfig.io (-sh): 3833 Starting Script Execution (-sh): 3833 IPSET created: US_vpn1 hash:net family inet hashsize 1024 maxelem 65536 (-sh): 3833 CRON schedule created: #US_vpn1# '0 2 * * * ipset save US_vpn1' (-sh): 3833 Selective Routing Rule via VPN Client 1 created for US_vpn1 (TAG fwmark 0x1000/0x1000) (-sh): 3833 Completed Script Execution admin@RT-AC68U-5358:/jffs/scripts/x3mRouting#
still, access to ifconfig.io is being done through wan
some diagnostics in case you can give me a hand
Code:admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# iptables -nvL PREROUTING -t mangle --line Chain PREROUTING (policy ACCEPT 9794 packets, 12M bytes) num pkts bytes target prot opt in out source destination 1 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set US_vpn1 dst MARK or 0x1000
dont know why a ovpcn3 shows
Code:admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# ip rule 0: from all lookup local 9993: from all fwmark 0x4000/0x4000 lookup ovpnc3 9995: from all fwmark 0x1000/0x1000 lookup ovpnc1 32766: from all lookup main 32767: from all lookup default admin@RT-AC68U-5358:/jffs/scripts/x3mRouting#
my dnsmasq.conf.add file
Code:strict-order dhcp-option=lan,42,10.0.0.1 # ntpMerlin server=/pool.ntp.org/1.1.1.1 ipset=/pandora.com/US_vpn1 ipset=/ifconfig.io/US_vpn1
sh load_DNSMASQ_ipset_iface.sh 1 US_vpn1 pandora.com
ipset -L US_vpn1
Type: hash:net
Revision: 6
Size in memory: 316
References: 1
Members:
#ipset -L US_vpn1
Type: hash:net
Revision: 6
Size in memory: 372
References: 1
Number of entries: 1
Members:
208.85.40.20
service_restart dnsmasq
ipset add US_vpn1 208.85.40.20
ipset add US_vpn1 208.85.40.20 pandora.com
I think I found a setting that may be causing the issue. Go to Tools -> Other Settings and set local caching to yes. Now, when I perform an nslookup on pandora.com, the IPSET is getting populated. Note to @Martineau.hi,
and ran option 3
Policy routing for a handful of domains or websites can be done using the Policy Routing section of the OpenVPN Client Screen and will probably meet the requirements of most people. But for some sites like Netflix, there are many IP addresses:I'm probably not understanding this, but I use policy rules under a vpn client to route RTP.PT through the client connected to a portuguese server, and everything else not through the vpn client. I expected it to be complicated but it wasn't.
ipset -L NETFLIX
Type: hash:net
Revision: 6
Size in memory: 7540
References: 1
Number of entries: 138
23.246.14.0/24
45.57.72.0/24
23.246.57.0/24
45.57.19.0/24
45.57.7.0/24
<snip>
admin@RT-AC68U-5358:/tmp/home/root# ipset -L US_vpn1
Type: hash:net
Revision: 6
Size in memory: 484
References: 1
Number of entries: 3
Members:
104.24.123.146
208.85.40.20
104.24.122.146
andresmorago@RT-AC68U-5358:/tmp/home/root# tail -f /opt/var/log/dnsmasq.log | grep ipset
May 25 22:54:59 dnsmasq[19532]: ipset add US_vpn1 208.85.40.20 pandora.com
May 25 22:54:59 dnsmasq[19532]: ipset add US_vpn1 2620:106:e003:f00e::63 pandora.com
May 25 22:55:04 dnsmasq[19532]: ipset add US_vpn1 104.24.122.146 ifconfig.io
May 25 22:55:04 dnsmasq[19532]: ipset add US_vpn1 104.24.123.146 ifconfig.io
May 25 22:55:04 dnsmasq[19532]: ipset add US_vpn1 2606:4700:30::6818:7b92 ifconfig.io
May 25 22:55:04 dnsmasq[19532]: ipset add US_vpn1 2606:4700:30::6818:7a92 ifconfig.io
I ran the script for Pandora and was able to have the traffic routed. I first used my Private IP in US and it worked. I then tested using a shared VPN server in LA. By doing this, I wanted to see if Pandora was blocking known VPN servers.@Xentrk
Hello and thanks!
i checked the Wan: Use local caching DNS server as system resolver (default: Yes) and its been ON all the time
i have restarted dnsmasq several times and rebooted with no good results.
list is now populated but still, traffic to pandora.com and ifconfig.io goes through wan and not the ovpn client 1. i can verify this as pandora is geoblocked on my country and ipinfo will show my wan ip address
Code:admin@RT-AC68U-5358:/tmp/home/root# ipset -L US_vpn1 Name: US_vpn1 Type: hash:net Revision: 6 Header: family inet hashsize 1024 maxelem 65536 Size in memory: 484 References: 1 Number of entries: 3 Members: 104.24.123.146 208.85.40.20 104.24.122.146
here is also the dnsmasq log
Code:andresmorago@RT-AC68U-5358:/tmp/home/root# tail -f /opt/var/log/dnsmasq.log | grep ipset May 25 22:54:59 dnsmasq[19532]: ipset add US_vpn1 208.85.40.20 pandora.com May 25 22:54:59 dnsmasq[19532]: ipset add US_vpn1 2620:106:e003:f00e::63 pandora.com May 25 22:55:04 dnsmasq[19532]: ipset add US_vpn1 104.24.122.146 ifconfig.io May 25 22:55:04 dnsmasq[19532]: ipset add US_vpn1 104.24.123.146 ifconfig.io May 25 22:55:04 dnsmasq[19532]: ipset add US_vpn1 2606:4700:30::6818:7b92 ifconfig.io May 25 22:55:04 dnsmasq[19532]: ipset add US_vpn1 2606:4700:30::6818:7a92 ifconfig.io
what else can i do?
an extra question: if i reboot, how can i make sure i dont lose the configuration?
thanks
Chain PREROUTING (policy ACCEPT 16463 packets, 4034K bytes)
1 1920 2413K MARK all -- tun15 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
2 0 0 MARK all -- tun14 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
3 0 0 MARK all -- tun13 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
4 17845 14M MARK all -- tun12 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
5 4949 2871K MARK all -- tun11 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
6 0 0 MARK all -- tun21 * 0.0.0.0/0 0.0.0.0/0 MARK xset 0x1/0x7
7 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set NETFLIX dst MARK or 0x1000
8 30 2200 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set HULU_WEB dst MARK or 0x1000
9 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set BBC_WEB dst MARK or 0x4000
10 901 49186 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set CBS_WEB dst MARK or 0x3000
11 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set MOVETV dst MARK or 0x3000
12 75 7751 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set US_vpn1 dst MARK or 0x2000
admin@RT-AC68U-5358:/tmp/home/root# /usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/Xentrk/x3mRouting/master/install_x3mRouting.sh" -o "/jffs/scripts
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 20846 100 20846 0 0 14837 0 0:00:01 0:00:01 --:--:-- 25863
_______________________________________________________________________
| Welcome to the x3mRouting installation script |
| Version 1.0.0 by Xentrk |
| ____ _ _ |
| |__ | | | | | |
| __ __ _| |_ _ _ | |_ ___ | | __ ____ ____ _ _ _ |
| \ \/ / |_ | ` ` \ __|/ _ \| |/ / / _// \| ` ` \ |
| / / __| | | | | |_ | __/| < ( (_ | [] || | | | |
| /_/\_\|___ |_|_|_|\___|\___||_|\_\[] \___\\____/|_|_|_| |
|_____________________________________________________________________|
| Requirements: jffs partition and USB drive with entware installed |
| See the project repository at |
| https://github.com/Xentrk/x3mRouting |
| for helpful tips. |
[1] = Install x3mRouting for LAN Clients
[2] = Install x3mRouting OpenVPN Client GUI & IPSET Shell Scripts
[3] = Install x3mRouting IPSET Shell Scripts
[4] = Check for updates to existing x3mRouting installation
[5] = Force update existing x3mRouting installation
[6] = Remove x3mRouting Repository
[e] = Exit Script
Option ==> 3
Installing jq (1.6-1) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/jq_1.6-1_armv7-2.6.ipk
Configuring jq.
jq successfully installed
Created project directory /jffs/scripts/x3mRouting
load_MANUAL_ipset_iface.sh downloaded successfully
load_ASN_ipset_iface.sh downloaded successfully
load_DNSMASQ_ipset_iface.sh downloaded successfully
load_AMAZON_ipset_iface.sh downloaded successfully
Installation of x3mRouting for IPSET Shell Scripts completed
Press enter to continue
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# . load_DNSMASQ_ipset_iface.sh 1 US_vpn pandora.com
(-sh): 3248 Starting Script Execution
(-sh): 3248 IPSET created: US_vpn hash:net family inet hashsize 1024 maxelem 65536
(-sh): 3248 CRON schedule created: #US_vpn# '0 2 * * * ipset save US_vpn'
(-sh): 3248 Selective Routing Rule via VPN Client 1 created for US_vpn (TAG fwmark 0x1000/0x1000)
(-sh): 3248 Completed Script Execution
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# . load_DNSMASQ_ipset_iface.sh 1 US_vpn ifconfig.io
0 2 * * * ipset save US_vpn > /opt/tmp/US_vpn #US_vpn#
Chain PREROUTING (policy ACCEPT 2412 packets, 1354K bytes)
1 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set US_vpn dst MARK or 0x1000
Type: hash:net
Revision: 6
Size in memory: 316
References: 1
Members:
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# nslookup pandora.com
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 2620:106:e003:f00e::63
Address 2: 208.85.40.20 www.pandora.com
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# nslookup ifconfig.io
Server: 127.0.0.1
Address 1: 2606:4700:30::6818:7a92
Address 2: 104.24.122.146
Address 3: 104.24.123.146
Type: hash:net
Revision: 6
Size in memory: 484
References: 1
Members:
208.85.40.20
104.24.122.146
104.24.123.146
Chain PREROUTING (policy ACCEPT 5152 packets, 1984K bytes)
1 33 3036 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set US_vpn dst MARK or 0x1000
admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# traceroute pandora.com
traceroute to pandora.com (208.85.40.20), 30 hops max, 38 byte packets
1 * * *
2 172.21.113.198 (172.21.113.198) 12.136 ms 8.582 ms 7.891 ms
3 190.85.254.145 (190.85.254.145) 10.585 ms 13.329 ms 15.008 ms
4 10.14.16.18 (10.14.16.18) 39.771 ms 34.652 ms 39.599 ms
5 10.14.18.41 (10.14.18.41) 32.124 ms 85.490 ms 39.845 ms
6 ix-et-2-0-2-0.tcore2.a56-atlanta.as6453.net (64.86.8.37) 78.584 ms 70.571 ms atl-b22-link.telia.net (62.115.145.12) 71.286 ms
7 if-ae-43-2.tcore1.a56-atlanta.as6453.net (64.86.113.149) 73.825 ms * 73.541 ms
8 dls-b21-link.telia.net (80.91.246.75) 92.749 ms 209.58.44.2 (209.58.44.2) 72.557 ms dls-b21-link.telia.net (80.91.246.75) 94.225 ms
9 las-b21-link.telia.net (62.115.123.137) 121.568 ms be-11491-cr02.56marietta.ga.ibone.comcast.net (68.86.83.177) 75.537 ms las-b21-link.telia.net (62.115.123.137) 123.615 ms
10 be-11423-cr01.houston.tx.ibone.comcast.net (68.86.85.22) 91.553 ms 93.387 ms sjo-b21-link.telia.net (62.115.116.40) 131.133 ms
11 be-11523-cr02.losangeles.ca.ibone.comcast.net (68.86.87.173) 122.840 ms pandora-ic-318321-sjo-b21.c.telia.net (213.248.85.255) 129.119 ms 131.700 ms
12 be-11525-cr01.9greatoaks.ca.ibone.comcast.net (68.86.84.150) 129.933 ms www.pandora.com (208.85.40.20) 133.533 ms be-11525-cr01.9greatoaks.ca.ibone.comcast.net (68.86.84.150) 130.298 ms
/x3mRouting#
#strict-order
@Xentrk hello again
still, no luck.i have taken into account all your recommendations. still. traffic to pandora.com and ifconfig.io (my 2 test websites) is going through wan and not tun11
i have restarted dnsmasq and rebooted router several times
i only have 1 openvpn client running and have tested it on a different device which confirms that the vpn doesnt block these 2 websites.
i also tried everything again from scratch
installing your script
Code:admin@RT-AC68U-5358:/tmp/home/root# /usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/Xentrk/x3mRouting/master/install_x3mRouting.sh" -o "/jffs/scripts /install_x3mRouting.sh" && chmod 755 /jffs/scripts/install_x3mRouting.sh && sh /jffs/scripts/install_x3mRouting.sh % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 20846 100 20846 0 0 14837 0 0:00:01 0:00:01 --:--:-- 25863 _______________________________________________________________________ | | | Welcome to the x3mRouting installation script | | Version 1.0.0 by Xentrk | | ____ _ _ | | |__ | | | | | | | __ __ _| |_ _ _ | |_ ___ | | __ ____ ____ _ _ _ | | \ \/ / |_ | ` ` \ __|/ _ \| |/ / / _// \| ` ` \ | | / / __| | | | | |_ | __/| < ( (_ | [] || | | | | | /_/\_\|___ |_|_|_|\___|\___||_|\_\[] \___\\____/|_|_|_| | |_____________________________________________________________________| | | | Requirements: jffs partition and USB drive with entware installed | | | | See the project repository at | | https://github.com/Xentrk/x3mRouting | | for helpful tips. | |_____________________________________________________________________| [1] = Install x3mRouting for LAN Clients [2] = Install x3mRouting OpenVPN Client GUI & IPSET Shell Scripts [3] = Install x3mRouting IPSET Shell Scripts [4] = Check for updates to existing x3mRouting installation [5] = Force update existing x3mRouting installation [6] = Remove x3mRouting Repository [e] = Exit Script Option ==> 3 Installing jq (1.6-1) to root... Downloading http://bin.entware.net/armv7sf-k2.6/jq_1.6-1_armv7-2.6.ipk Configuring jq. jq successfully installed Created project directory /jffs/scripts/x3mRouting load_MANUAL_ipset_iface.sh downloaded successfully load_ASN_ipset_iface.sh downloaded successfully load_DNSMASQ_ipset_iface.sh downloaded successfully load_AMAZON_ipset_iface.sh downloaded successfully Installation of x3mRouting for IPSET Shell Scripts completed Press enter to continue
running load_DNSMASQ_ipset_iface.sh
Code:admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# . load_DNSMASQ_ipset_iface.sh 1 US_vpn pandora.com (-sh): 3248 Starting Script Execution (-sh): 3248 IPSET created: US_vpn hash:net family inet hashsize 1024 maxelem 65536 (-sh): 3248 CRON schedule created: #US_vpn# '0 2 * * * ipset save US_vpn' (-sh): 3248 Selective Routing Rule via VPN Client 1 created for US_vpn (TAG fwmark 0x1000/0x1000) (-sh): 3248 Completed Script Execution admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# . load_DNSMASQ_ipset_iface.sh 1 US_vpn ifconfig.io (-sh): 3248 Starting Script Execution 0 2 * * * ipset save US_vpn > /opt/tmp/US_vpn #US_vpn# (-sh): 3248 Selective Routing Rule via VPN Client 1 created for US_vpn (TAG fwmark 0x1000/0x1000) (-sh): 3248 Completed Script Execution
diagnostics
Code:admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# iptables -nvL PREROUTING -t mangle --line Chain PREROUTING (policy ACCEPT 2412 packets, 1354K bytes) num pkts bytes target prot opt in out source destination 1 0 0 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set US_vpn dst MARK or 0x1000 admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# ip rule 0: from all lookup local 9995: from all fwmark 0x1000/0x1000 lookup ovpnc1 32766: from all lookup main 32767: from all lookup default admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# ipset -L US_vpn Name: US_vpn Type: hash:net Revision: 6 Header: family inet hashsize 1024 maxelem 65536 Size in memory: 316 References: 1 Number of entries: 0 Members: admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# nslookup pandora.com Server: 127.0.0.1 Address 1: 127.0.0.1 localhost.localdomain Name: pandora.com Address 1: 2620:106:e003:f00e::63 Address 2: 208.85.40.20 www.pandora.com admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# nslookup ifconfig.io Server: 127.0.0.1 Address 1: 127.0.0.1 localhost.localdomain Name: ifconfig.io Address 1: 2606:4700:30::6818:7a92 Address 2: 104.24.122.146 Address 3: 104.24.123.146 admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# ipset -L US_vpn Name: US_vpn Type: hash:net Revision: 6 Header: family inet hashsize 1024 maxelem 65536 Size in memory: 484 References: 1 Number of entries: 3 Members: 208.85.40.20 104.24.122.146 104.24.123.146 admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# iptables -nvL PREROUTING -t mangle --line Chain PREROUTING (policy ACCEPT 5152 packets, 1984K bytes) num pkts bytes target prot opt in out source destination 1 33 3036 MARK all -- br0 * 0.0.0.0/0 0.0.0.0/0 match-set US_vpn dst MARK or 0x1000
when i run a traceroute from my router to pandora.com i can clearly see that traffic doesnt go through vpn client 1. hop #3 is a local ISP router.
Code:admin@RT-AC68U-5358:/jffs/scripts/x3mRouting# traceroute pandora.com traceroute to pandora.com (208.85.40.20), 30 hops max, 38 byte packets 1 * * * 2 172.21.113.198 (172.21.113.198) 12.136 ms 8.582 ms 7.891 ms 3 190.85.254.145 (190.85.254.145) 10.585 ms 13.329 ms 15.008 ms 4 10.14.16.18 (10.14.16.18) 39.771 ms 34.652 ms 39.599 ms 5 10.14.18.41 (10.14.18.41) 32.124 ms 85.490 ms 39.845 ms 6 ix-et-2-0-2-0.tcore2.a56-atlanta.as6453.net (64.86.8.37) 78.584 ms 70.571 ms atl-b22-link.telia.net (62.115.145.12) 71.286 ms 7 if-ae-43-2.tcore1.a56-atlanta.as6453.net (64.86.113.149) 73.825 ms * 73.541 ms 8 dls-b21-link.telia.net (80.91.246.75) 92.749 ms 209.58.44.2 (209.58.44.2) 72.557 ms dls-b21-link.telia.net (80.91.246.75) 94.225 ms 9 las-b21-link.telia.net (62.115.123.137) 121.568 ms be-11491-cr02.56marietta.ga.ibone.comcast.net (68.86.83.177) 75.537 ms las-b21-link.telia.net (62.115.123.137) 123.615 ms 10 be-11423-cr01.houston.tx.ibone.comcast.net (68.86.85.22) 91.553 ms 93.387 ms sjo-b21-link.telia.net (62.115.116.40) 131.133 ms 11 be-11523-cr02.losangeles.ca.ibone.comcast.net (68.86.87.173) 122.840 ms pandora-ic-318321-sjo-b21.c.telia.net (213.248.85.255) 129.119 ms 131.700 ms 12 be-11525-cr01.9greatoaks.ca.ibone.comcast.net (68.86.84.150) 129.933 ms www.pandora.com (208.85.40.20) 133.533 ms be-11525-cr01.9greatoaks.ca.ibone.comcast.net (68.86.84.150) 130.298 ms /x3mRouting#
dnsmasq.conf.add
Code:#strict-order #server=3.16.174.94 dhcp-option=lan,42,10.0.0.1 # ntpMerlin server=/pool.ntp.org/1.1.1.1 ipset=/pandora.com/US_vpn ipset=/ifconfig.io/US_vpn
vpn is working correctly
*i have full access to server. tried to connect from a different client and works
*pings from router to my vpn server are ok. also, i can force a traceroute through vpn client 1 and hops show traffic being router like i need to.
ip route show table main | grep -E "^0\.|^128.|^default"
ip route show table ovpnc1
nvram get ctf_disable
nvram get ctf_fa_mode
ASUSWRT-Merlin RT-AC68U 384.11-0 Wed May 8 22:14:43 UTC 2019
admin@RT-AC68U-5358:/tmp/home/root# ip route show table main | grep -E "^0\.|^128.|^default"
default via 181.56.148.1 dev eth0
admin@RT-AC68U-5358:/tmp/home/root# ip route show table ovpnc1
10.0.0.0/24 dev br0 proto kernel scope link src 10.0.0.1
10.0.2.0/24 dev tun11 proto kernel scope link src 10.0.2.3
10.0.0.0/8 dev br0 proto kernel scope link src 10.0.0.6
admin@RT-AC68U-5358:/tmp/home/root# nvram get ctf_disable
1
admin@RT-AC68U-5358:/tmp/home/root# nvram get ctf_fa_mode
Type: hash:net
Revision: 6
Size in memory: 428
References: 1
Number of entries: 2
Members:
admin@RT-AC68U-5358:/tmp/home/root# ping pandora.com
PING pandora.com (208.85.40.20): 56 data bytes
64 bytes from 208.85.40.20: seq=0 ttl=239 time=134.389 ms
--- pandora.com ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 134.381/134.385/134.389 ms
admin@RT-AC68U-5358:/tmp/home/root# ping ifconfig.io
PING ifconfig.io (104.24.122.146): 56 data bytes
64 bytes from 104.24.122.146: seq=0 ttl=54 time=91.313 ms
--- ifconfig.io ping statistics ---
1 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 90.109/90.711/91.313 ms
Type: hash:net
Revision: 6
Size in memory: 484
References: 1
Members:
104.24.123.146
208.85.40.20
104.24.122.146
admin@RT-AC68U-5358:/tmp/home/root# liststats
-sh: liststats: not found
alias FreshJR_QOS="sh /jffs/scripts/FreshJR_QOS -menu"
alias freshjr="sh /jffs/scripts/FreshJR_QOS -menu"
alias freshjrqos="sh /jffs/scripts/FreshJR_QOS -menu"
alias freshjr_qos="sh /jffs/scripts/FreshJR_QOS -menu"
For liststats, check if the file /jffs/configs/profile.add exists. Type:i have also noticed that the install script isnt enabling the liststats function. i have restarted putty and get
Code:admin@RT-AC68U-5358:/tmp/home/root# liststats -sh: liststats: not found
profile.add
Code:alias FreshJR_QOS="sh /jffs/scripts/FreshJR_QOS -menu" alias freshjr="sh /jffs/scripts/FreshJR_QOS -menu" alias freshjrqos="sh /jffs/scripts/FreshJR_QOS -menu" alias freshjr_qos="sh /jffs/scripts/FreshJR_QOS -menu" alias FreshJR_QOS="sh /jffs/scripts/FreshJR_QOS -menu"
ls -al /jffs/configs | grep profile.add
And show me the output.Code:ls -al /jffs/configs | grep profile.add
Update:
I renamed my existing profile.add to profile.add.bkup and ran the installer. /jffs/configs/profile.add was created and I was able to run the command after opening up a new SSH session.
admin@RT-AC68U-5358:/tmp/home/root# ls -al /jffs/configs | grep profile.add
-rw-rw-rw- 1 admin root 270 Mar 18 15:35 profile.add
Every 24 hours at 2:00 am, a backup copy of the current IPSET list is made to /opt/tmp. This will allow the IPSET list to be restored upon system boot. dnsmasq is supposed to auto populate the IPSET list. But as I found with 384.12 alpha release, it wasn't working as expected unless DNS local cache was set to Yes. If you have rebooted before the cron job could run, the backup never got created. After you have the ipset list populated with the three entries, type the following command to save the backup. This should prevent the issue from occurring in the future after a reboot:hello again
some minor issues:
i have noticed that when i first call any of the websites, traffic will first go through wan. i have to ping websites from router first so i can have them be routed through vpn
Code:admin@RT-AC68U-5358:/tmp/home/root# ipset -L US_vpn Name: US_vpn Type: hash:net Revision: 6 Header: family inet hashsize 1024 maxelem 65536 Size in memory: 428 References: 1 Number of entries: 2 Members: admin@RT-AC68U-5358:/tmp/home/root# ping pandora.com PING pandora.com (208.85.40.20): 56 data bytes 64 bytes from 208.85.40.20: seq=0 ttl=239 time=134.389 ms --- pandora.com ping statistics --- 2 packets transmitted, 2 packets received, 0% packet loss round-trip min/avg/max = 134.381/134.385/134.389 ms admin@RT-AC68U-5358:/tmp/home/root# ping ifconfig.io PING ifconfig.io (104.24.122.146): 56 data bytes 64 bytes from 104.24.122.146: seq=0 ttl=54 time=91.313 ms --- ifconfig.io ping statistics --- 1 packets transmitted, 2 packets received, 0% packet loss round-trip min/avg/max = 90.109/90.711/91.313 ms admin@RT-AC68U-5358:/tmp/home/root# ipset -L US_vpn Name: US_vpn Type: hash:net Revision: 6 Header: family inet hashsize 1024 maxelem 65536 Size in memory: 484 References: 1 Number of entries: 3 Members: 104.24.123.146 208.85.40.20 104.24.122.146
ipset save US_VPN > /opt/tmp/US_VPN
Thanks for letting me know. I think I see the issue. But I need to wait until tomorrow to fix and test as it's getting late in my time zone and I might make a mistake. For now, copy the code below to /jffs/configs/profile.add:hi.
ouput
Code:admin@RT-AC68U-5358:/tmp/home/root# ls -al /jffs/configs | grep profile.add -rw-rw-rw- 1 admin root 270 Mar 18 15:35 profile.add
please take into account that my profile.add has extra lines already from freshJR qos script.
# List number of entries in each IPSET list
# Usage: liststats
liststats () {
GREEN='\033[0;32m'
RED='\033[0;31m'
NC='\033[0m' # No Color
true > /tmp/liststats
for SETLIST in $(ipset -L -n); do
printf '%s - %b%s%b\n' "$SETLIST" "$GREEN" "$(($(ipset -L "$SETLIST" | wc -l) - 8))" "$NC" >> /tmp/liststats
done
cat /tmp/liststats | sort
rm /tmp/liststats
/jffs/scripts# liststats
AMAZON_US - 331
BBC_WEB - 135
CBS_WEB - 134
HULU_WEB - 9
MOVETV - 117
NETFLIX - 150
Skynet-Blacklist - 157564
Skynet-BlockedRanges - 1569
Skynet-IOT - 0
Skynet-Master - 2
Skynet-Whitelist - 3512
US_VPN - 1
Welcome To SNBForums
