A funny thing is some people still saying it's ok. They even say 100C-120C is ok.Hey guys, I hope everyone is okay during the challenging times.
I run electronics recycling business on the side and I repair electronics as a hobby. Component level repairs from PC motherboards to iPhones. I have my small lab with what's needed for my fun projects. A few resurrected RT-AC86U routers are sitting on my shelf. Those fail in big numbers. Asus is reusing parts from previous models and they don't fit properly. Some of you may have noticed a number of huge thermal transfer pads. The gaps between the ICs and the heatsink are as large as 3mm. It's built as cheap as possible with hope for the best. There are many thermal stress points on this PCB. It lights up like NYC night lights on the thermal camera image. Lead free solder doesn't like thermal stress points. VRMs fail as well as RF ICs. I had to replace few VRMs and reflow a RF IC to bring a few back to life. The repair is not worth it. Fix one thing and something else fails. The bad design always wins. Using copper shims and thermal paste drops the temperatures you report by 20C. A fan on top drops it further another 20C. My general recommendation is to avoid this model. If you already have it avoid on/off cycles to reduce the thermal stress. A fan is a workaround temporary solution. When the VRMs fail you get one LAN port light lit or some other LED half lit. When the RF IC fails you get Channel 0 in your UI. I don't know why Asus uses 19V PS and then drops the voltages down with multiple VRMs. It only creates more failure points and generates more heat. Other routers do fine with 6-12V PS. I can't find schematics online for Asus routers. Looking at the components used nothing needs 19V. Good luck to RT-AC86U owners.
Release - RT-AC86U 11th January 2021 Firmware version 3.0.0.4.386.41634
Yes. But you will need a USB drive of some sort inserted to trigger the process. (There may be another way, too) Enable SSH access LAN only. In a terminal (Putty is great for this) log into your router You will use the VI editor to create a file and enter contents vi /jffs/post-mount (Enter)...
