RT-AC3200 FW .9313 kernel bug
Puppa
Just saw "scheduling while atomic" bug come up in my syslog. Will post full log when I get back home.
There seems to be a problem at DHCP renewal--I've seen a number of resets when DHCP expires, but this is the first time the underlying error made it into the syslog for something concrete. Will post here and via the "feedback" tab.
Here's the syslog...
Dec 6 00:59:57 ntp: start NTP update
Dec 6 01:59:57 ntp: start NTP update
Dec 6 02:59:59 ntp: start NTP update
Dec 6 04:00:01 ntp: start NTP update
Dec 6 04:59:57 ntp: start NTP update
Dec 6 05:59:57 ntp: start NTP update
Dec 6 06:59:57 ntp: start NTP update
Dec 6 07:59:57 ntp: start NTP update
Dec 6 08:59:59 ntp: start NTP update
Dec 6 09:59:57 ntp: start NTP update
Dec 6 10:59:59 ntp: start NTP update
Dec 6 11:47:28 WAN Connection: Ethernet link down.
Dec 6 11:47:28 DualWAN: skip single wan wan_led_control - WANRED off
Dec 6 11:47:39 WAN Connection: Ethernet link up.
Dec 6 11:47:39 rc_service: wanduck 464:notify_rc restart_wan_if 0
Dec 6 11:47:39 ntp: start NTP update
Dec 6 11:47:39 kernel: BUG: scheduling while atomic: preinit/1/0x00000102
Dec 6 11:47:39 kernel: module: dhd bf61d000 768584
Dec 6 11:47:39 kernel: module: cdc_mbim bf3ec000 3129
Dec 6 11:47:40 kernel: module: qmi_wwan bf3e5000 5780
Dec 6 11:47:40 kernel: module: cdc_wdm bf3de000 7248
Dec 6 11:47:40 kernel: module: cdc_ncm bf3d6000 8750
Dec 6 11:47:40 kernel: module: rndis_host bf3cf000 4936
Dec 6 11:47:40 kernel: module: cdc_ether bf3c9000 3187
Dec 6 11:47:40 kernel: module: asix bf3c1000 10832
Dec 6 11:47:40 kernel: module: usbnet bf3b8000 11165
Dec 6 11:47:40 kernel: module: mii bf3b2000 3367
Dec 6 11:47:40 kernel: module: usblp bf3aa000 10317
Dec 6 11:47:40 kernel: module: ohci_hcd bf3a0000 17918
Dec 6 11:47:40 kernel: module: ehci_hcd bf393000 31653
Dec 6 11:47:40 kernel: module: xhci_hcd bf380000 50352
Dec 6 11:47:40 kernel: module: nf_nat_sip bf379000 5031
Dec 6 11:47:40 kernel: module: thfsplus bf35c000 85425
Dec 6 11:47:40 kernel: module: nf_conntrack_sip bf353000 15713
Dec 6 11:47:40 kernel: module: nf_nat_h323 bf34c000 4761
Dec 6 11:47:40 kernel: module: tntfs bf2c0000 462074
Dec 6 11:47:40 kernel: module: nf_conntrack_h323 bf33e000 33807
Dec 6 11:47:40 kernel: module: nf_nat_rtsp bf2ba000 3202
Dec 6 11:47:40 kernel: module: nf_conntrack_rtsp bf2b4000 4067
Dec 6 11:47:40 kernel: module: nf_nat_ftp bf2ae000 1144
Dec 6 11:47:40 kernel: module: nf_conntrack_ftp bf2a7000 4909
Dec 6 11:47:40 kernel: module: tfat bf26f000 185978
Dec 6 11:47:40 kernel: module: ip6table_mangle bf269000 934
Dec 6 11:47:40 kernel: module: ext2 bf254000 53780
Dec 6 11:47:40 kernel: module: ext4 bf213000 222294
Dec 6 11:47:40 kernel: module: jbd2 bf1ff000 49549
Dec 6 11:47:40 kernel: module: crc16 bf1f9000 1007
Dec 6 11:47:40 kernel: module: ext3 bf1d6000 106581
Dec 6 11:47:40 kernel: module: jbd bf1c5000 42799
Dec 6 11:47:40 kernel: module: xt_length bf1bf000 769
Dec 6 11:47:40 kernel: module: mbcache bf1b8000 4599
Dec 6 11:47:40 kernel: module: usb_storage bf1a9000 34230
Dec 6 11:47:40 kernel: module: sg bf192000 20007
Dec 6 11:47:40 kernel: module: sd_mod bf186000 22167
Dec 6 11:47:40 kernel: module: scsi_wait_scan bf180000 416
Dec 6 11:47:40 kernel: module: scsi_mod bf15b000 108818
Dec 6 11:47:40 kernel: module: usbcore bf138000 102110
Dec 6 11:47:40 kernel: module: ip6t_LOG bf131000 4494
Dec 6 11:47:40 kernel: module: ip6table_filter bf12b000 750
Dec 6 11:47:40 kernel: module: jffs2 bf10d000 91530
Dec 6 11:47:40 kernel: module: zlib_deflate bf103000 19489
Dec 6 11:47:40 kernel: module: igs bf026000 11927
Dec 6 11:47:40 kernel: module: emf bf01d000 15169
Dec 6 11:47:40 kernel: module: et bf00a000 48925
Dec 6 11:47:40 kernel: module: ctf bf000000 16424
Dec 6 11:47:40 kernel: Modules linked in: dhd cdc_mbim qmi_wwan cdc_wdm cdc_ncm rndis_host cdc_ether asix usbnet mii usblp ohci_hcd ehci_hcd xhci_hcd nf_nat_sip thfsplus nf_conntrack_sip nf_nat_h323 tntfs(P) nf_conntrack_h323 nf_nat_rtsp nf_conntrack_rtsp nf_nat_ftp nf_conntrack_ftp tfat(P) ip6table_mangle ext2 ext4 jbd2 crc16 ext3 jbd xt_length mbcache usb_storage sg sd_mod scsi_wait_scan scsi_mod usbcore ip6t_LOG ip6table_filter jffs2 zlib_deflate igs(P) emf(P) et(P) ctf(P) [last unloaded: ip6t_REJEC
Dec 6 11:47:40 kernel: [<c0045ff8>] (unwind_backtrace+0x0/0xf8) from [<c02f28b4>] (schedule+0x434/0x784)
Dec 6 11:47:40 kernel: [<c02f28b4>] (schedule+0x434/0x784) from [<c02f3024>] (schedule_timeout+0x160/0x1c0)
Dec 6 11:47:40 kernel: [<c02f3024>] (schedule_timeout+0x160/0x1c0) from [<c02f2338>] (wait_for_common+0xc0/0x164)
Dec 6 11:47:40 kernel: [<c02f2338>] (wait_for_common+0xc0/0x164) from [<c0079784>] (flush_workqueue+0x11c/0x424)
Dec 6 11:47:40 kernel: [<c0079784>] (flush_workqueue+0x11c/0x424) from [<bf00b00c>] (et_down+0xf8/0x16c [et])
Dec 6 11:47:40 kernel: [<bf00b00c>] (et_down+0xf8/0x16c [et]) from [<bf00b178>] (et_close+0x70/0x8c [et])
Dec 6 11:47:40 kernel: [<bf00b178>] (et_close+0x70/0x8c [et]) from [<c0212c20>] (__dev_close+0x64/0x9c)
Dec 6 11:47:40 kernel: [<c0212c20>] (__dev_close+0x64/0x9c) from [<c0213bbc>] (__dev_change_flags+0x7c/0x134)
Dec 6 11:47:40 kernel: [<c0213bbc>] (__dev_change_flags+0x7c/0x134) from [<c0213cfc>] (dev_change_flags+0x10/0x48)
Dec 6 11:47:40 kernel: [<c0213cfc>] (dev_change_flags+0x10/0x48) from [<c0279ca4>] (devinet_ioctl+0x69c/0x754)
Dec 6 11:47:40 kernel: [<c0279ca4>] (devinet_ioctl+0x69c/0x754) from [<c0200ff8>] (sock_ioctl+0x5c/0x250)
Dec 6 11:47:40 kernel: [<c0200ff8>] (sock_ioctl+0x5c/0x250) from [<c00daebc>] (do_vfs_ioctl+0x80/0x5d0)
Dec 6 11:47:40 kernel: [<c00daebc>] (do_vfs_ioctl+0x80/0x5d0) from [<c00db444>] (sys_ioctl+0x38/0x60)
Dec 6 11:47:40 kernel: [<c00db444>] (sys_ioctl+0x38/0x60) from [<c003fac0>] (ret_fast_syscall+0x0/0x30)
Dec 6 11:47:40 ntp: start NTP update
Dec 6 11:47:40 wan: mac clone: [wan0_hwaddr] == [02:0f:b5:e4:eb:c5]
Dec 6 11:47:42 ntp: start NTP update
Dec 6 11:47:42 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 6 11:47:43 wan: finish adding multi routes
Dec 6 11:47:43 rc_service: udhcpc 20530:notify_rc stop_upnp
Dec 6 11:47:43 rc_service: udhcpc 20530:notify_rc start_upnp
Dec 6 11:47:43 rc_service: waitting "stop_upnp" via udhcpc ...
Dec 6 11:47:43 miniupnpd[741]: shutting down MiniUPnPd
Dec 6 11:47:44 dhcp client: bound 192.168.100.11 via 192.168.100.1 during 20 seconds.
Dec 6 11:47:44 miniupnpd[20578]: version 1.9 started
Dec 6 11:47:44 miniupnpd[20578]: HTTP listening on port 44224
Dec 6 11:47:44 miniupnpd[20578]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 6 11:47:46 WAN Connection: WAN was restored.
Dec 6 11:48:09 dhcp6 client: bound address 2606:a000:bfc0:c3:35ed:d16e:2261:4265/128, prefix 2606:a000:1128:c131::/64
Dec 6 11:48:16 WAN Connection: ISP's DHCP did not function properly.
Dec 6 11:48:16 DualWAN: skip single wan wan_led_control - WANRED off
Dec 6 11:48:16 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 6 11:48:17 wan: finish adding multi routes
Dec 6 11:48:17 rc_service: udhcpc 20588:notify_rc stop_upnp
Dec 6 11:48:17 rc_service: udhcpc 20588:notify_rc start_upnp
Dec 6 11:48:17 rc_service: waitting "stop_upnp" via udhcpc ...
Dec 6 11:48:17 miniupnpd[20578]: shutting down MiniUPnPd
Dec 6 11:48:18 ntp: start NTP update
Dec 6 11:48:18 dhcp client: bound 71.70.193.205 via 71.70.192.1 during 49590 seconds.
Dec 6 11:48:19 miniupnpd[20644]: version 1.9 started
Dec 6 11:48:19 miniupnpd[20644]: HTTP listening on port 49833
Dec 6 11:48:19 miniupnpd[20644]: Listening for NAT-PMP/PCP traffic on port 5351
Dec 6 11:48:21 WAN Connection: WAN was restored.
Dec 6 11:48:26 dhcp6 client: bound address 2606:a000:bfc0:c3:35ed:d16e:2261:4265/128, prefix 2606:a000:1128:c131::/64
Dec 6 11:59:57 ntp: start NTP update
Dec 6 12:59:57 ntp: start NTP update
Dec 6 13:59:59 ntp: start NTP update
Dec 6 15:00:01 ntp: start NTP update
Dec 6 15:59:57 ntp: start NTP update
Dec 6 16:59:59 ntp: start NTP update
Dec 6 18:00:01 ntp: start NTP update
Dec 6 18:59:57 ntp: start NTP update
Dec 6 19:59:57 ntp: start NTP update
