Router info:
RT-AC66R from Best Buy.
Came pre-installed with whatever firmware ended in 354 I believe.
Now it has 3.0.0.4.374.32 RMerlin installed.
Wireless temps are steady @ 56 °C for 2.4GHz and 62 °C for 5GHz.
First some background info...
When I purchased this router, it was preloaded with the 354 firmware I believe and I was having major throughput issues - speeds fluctuated wildly. For example, when doing a speedtest, the meter would jump from 24Mbps down to 6Mbps then up to 14Mbps, etc, etc. Upload speeds were affected the same way. So in order to remedy the issue, I did a site survey and I tried changing the wireless channels and bandwidth settings in all possible combinations to no avail. (Channel 11 is basically completely empty here so I used and still use that channel mainly) I cleared the nvram, and reinstalled the firmware from Asus' website. Problem solved. Whew..
A week later, I noticed the 2.4GHz band was basically dead. Only one device was connected to the 2.4GHz band (a computer) and the rest had dropped off the network and as far as those devices were concerned, there was no 2.4GHz signal to connect to. The computer, however, remained connected, but only at 1.0Mbps, as Windows stated, but the actual speed was 0.01-0.1 Mbps when doing a speed test. So after reading online, and seeing how people opened up the configuration page for the 5GHz band and clicked "Apply" to basically reset the wireless, I did the same. And it worked. The 2.4GHz band reset and everything reconnected....until a week later, when the problem repeated. This has been occurring weekly since I've had this router...
Now to the present...
The problem repeated weekly until a few days ago, when I finally had enough. The same problem happened - 2.4GHz band dropped BUT this time, it cut off the internet connection. No devices, even connected through an ethernet cable, could reach any websites. The router was just dead. I had to power cycle it, and there it was again, working perfectly. So like I said - I had enough. I decided to clear the nvram, install RMerlin's latest build, 3.0.0.4.374.32, and clear the nvram again after install, and input all of my settings again manually instead of restoring from a file.
Now the 2.4GHz band is dropping once per day instead of once per week. Last night, when it dropped, it kicked the internet connection to the curb and I had to power cycle the router again, but even when I power cycled the router, it was still not working, so I did it again, and it started working.
This is just not acceptable. My older D-Link DIR-655 router NEVER had these issues. It was basically set and forget and had uptime of over a year once before the power went out and forced a reset. Now I'm resetting every single day?? I won't deal with this. Does anybody have any ideas? I'm only having issues on the 2.4GHz band, not the 5GHz band, but I've read of people having similar issues on both bands but not to this severity. Should I RMA it? Should I light it on fire? Help.
