RT-AC66U B1 dropping internet
finale solution is to disable the 5ghz WiFi. Go to advanced settings and disable the radio setting. I have been connected since doing that.
Disabling 5G can never be a final solution!
Its like skiing with only 1 ski ... or swimming with one arm and leg.
Come on, you bought a 5G Wifi router and disable 5G?
Next time you buy a 4K TV watching SD resolution.
My final solution instead: Use it as paperweight!
