My router came up properly, I configured it, then it somehow got stuck in rescue mode (power LED blinks slowly). I have tried EVERYTHING to do with resetting and wiping nvram and loading new firmware (old, new, stock, merlin, tomato) via the Mac Restoration tool, the CFE web GUI firmware loader and tftp and even waiting hours between steps, 30-30-30, but nothing works.
I finally got a serial connection up (a first for me) and here's what I see at boot:
**** Port Open
Decompressing...done
CFE version 6.30.39.29 (r338244) based on BBP 1.0.37 for BCM947XX (32bit,SP,LE)
Build Date: ä¸ 10æ 15 10:41:41 CST 2012 (yau@wireless-pub2)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Found a AMD NAND flash with 2048B pages or 128KB blocks; total size 128MB
bcm_robo_enable_switch: EEE is disabled
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.39.29 (r338244)
CPU type 0x19749: 600MHz
Tot mem: 131072 KBytes
CFE mem: 0x80700000 - 0x8094EDE0 (2420192)
Data: 0x80738B70 - 0x8073BE10 (12960)
BSS: 0x8073BE10 - 0x8074CDE0 (69584)
Heap: 0x8074CDE0 - 0x8094CDE0 (2097152)
Stack: 0x8094CDE0 - 0x8094EDE0 (8192)
Text: 0x80700000 - 0x80738B70 (232304)
Device eth0: hwaddr 60-A4-4C-6A-7F-48, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Null Rescue Flag.
boot the image...
I/O error
I/O error
Check 2 trx result: -4, -4
Hello!! Enter Rescue Mode: (Check error)
Reading :: TFTP Server.
Failed.: Timeout occured
...repeat forever...
If I load firmware via the tftp server, I get this:
- last blk -
Done. 26234880 bytes read
Download of 0x1905000 bytes completed
Write kernel and filesystem binary to FLASH
Programming…copysize=26234880, amtcopy=-4
Failed.: I/O error
...and with the Mac Restoration tool:
- last blk -
Failed.: I/O error
I'd really appreciate a reference to detailed, step by step instructions on how to update/replace the CFE, if that's the problem (which it seems to be by process of elimination) via a serial connection. I don't have telnet access (unless someone can tell me how to turn it on via serial). I've got hardware revision 1.30 and can ping & tftp it.
Any help much appreciated!
-Brad
**** Port Open
Init Arena
Init Devs.
Null Rescue Flag.
boot the image...
I/O error
I/O error
- last blk -
Failed.: I/O error
- last blk -
Failed.: I/O error
-Brad
