i have DHCP enabled and i am assigning ip adresses by using a MAC address table.
This works and every connected client(wired and wirelss) shows up with it's correct name under Client Status
however when i look under wireless log i see a couple of devices with assigned ip addresses but with no name behind it.
These devices have a name setup which is not empty
so either the name from the device is used or the name from the mac address table
in this case a third option seems to be used which is empty.
eg
Foscam camera name inside device:Foscam1
name in the mac address :Foscam1
info showed in wireless log(MAC address XX):
XX:XX:XX:XX:XX:XX 192.168.1.99 -53dBm ??/65 Mbps 00:52:07 AU
it should be like this(which i have with al the other devices)
XX:XX:XX:XX:XX:XX 192.168.1.99 Foscam1 -53dBm ??/65 Mbps 00:52:07 AU
so why is it not showing a name
i have this problem with a foscam camera and hp wifi printer
eg
