Rt-ac68u connection stability issue on 378.56_2
Remove/Disable the VPN and wait the 30 minutes and you will recognize that your firewall-start script messes the things up (or not)... :eek:
...or you stop using the the useless TrendMicro stuff which triggers the unstable firewall-settings to be used multiple times! :rolleyes:
I've deleted the JFFS scripts all together and have just set some policy rules to route specific IP addresses to VPN. It seems like its working the same way, I just set static IP addresses for the two devices I want to use the VPN on, and if I want to bypass the VPN I can change the IP addresses manually/using the .bat file. Is there anything different/wrong with doing it this way than through JFFS script susing openvpn_event and firewall-start?
Also, its concerning that there is trendmicro stuff triggering the firewall rules, because I don't have any trend micro running on any of my devices, unless its an inbuilt router feature I haven't disabled?
