I simply upgraded to this new firmware from the previous version without clearing nor reloading any configurations. It has been working just fine since I've loaded it. I don't use all the fancy QOS or anything though. Just using it for basic router connectivity. I do have all the AIProtection choices enabled. No hiccups or connection issues so far since I've loaded this new firmware. Also, I simply just loaded it and did not even power off and power on the router. I just let it update and reboot itself and been off and running since yesterday without any connection issues.
Oh, Oh! I just looked at the syslog this evening and see a ton of repeating messages occurring continuously at intervals. Here is a cut and pasted sample of what I am seeing: (What's up with that? I did not have any of that nonsense on the previous firmware!):
Mar 13 13:59:57 ntp: start NTP update
Mar 13 14:03:44 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:10:30 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:11:26 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:14:33 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:15:35 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:20:48 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:25:52 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:32:47 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:36:09 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:41:23 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:42:24 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:46:30 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:50:38 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:51:39 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:53:43 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 14:59:57 ntp: start NTP update
Mar 13 15:20:32 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 15:44:14 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 15:48:19 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 15:52:15 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 15:54:29 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 15:59:57 ntp: start NTP update
Mar 13 16:02:46 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:06:53 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:12:39 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:13:05 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:14:08 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:15:10 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:16:11 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:23:24 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:24:54 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:27:33 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:32:41 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:34:45 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:36:50 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:42:00 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:44:03 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:46:06 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:46:26 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:52:41 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:55:33 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 16:59:57 ntp: start NTP update
Mar 13 17:00:35 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:05:00 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:14:11 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:15:02 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:18:08 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:20:12 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:30:31 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:36:43 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:39:49 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:44:56 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:46:59 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:54:10 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 17:59:59 ntp: start NTP update
Mar 13 18:00:02 ntp: start NTP update
Mar 13 18:04:33 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:06:31 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:07:14 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:08:33 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:09:35 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:12:41 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:16:48 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:26:04 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:30:13 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:40:52 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:43:37 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:45:41 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:54:34 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 18:59:57 ntp: start NTP update
Mar 13 19:04:18 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:07:23 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:14:39 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:15:02 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:18:46 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:28:03 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:39:23 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:42:35 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:47:37 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:53:49 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:58:03 miniupnpd[700]: sendto(udp): Operation not permitted
Mar 13 19:59:57 ntp: start NTP update
Mar 13 20:07:14 miniupnpd[700]: sendto(udp): Operation not permitted
