runar
I bought a brand new RT-AC68W (RT-AC68U White) yesterday for replacement of my old Netgear AP with hopes to AIMesh working with my already existing RT-AC68U that I have been running for a number of years.
I updated and performed a factory reset on my main router (RT-AC68U) and notice the added functionality for AIMesh in the GUI. Made a basic setup to get it up and running.
Then I hooked up the new RT-AC68W, made a quick setup and updated the firmware to the same release as the main node. Performed a factory reset.
Now, going back to my main router, I search for a new node.. But times out without finding it. Did this a number of times, even tried with cable (Node WAN -> Router LAN) but still can't find it.
So, then I decide to swith it around, use the new RT-AC68W as main router instead. So, factory reset again and quick setup as a AIMesh Router. Reconnect and open GUI, but no AIMesh in the GUI? Strange thing is that you can select AIMesh roles in the quick-wizard so obviosly loading the correct FW.
But why is it not showing the AIMesh symbol in the UI (even tried the ASUS Router app in my iPad)?
I even tried flashing with the RT-AC68U image, but same result.
RT-AC68U White (RT-AC68W) is listed as supported on the main ASUS AIMesh page, and the Firmware image is available for download, and it will update through the GUI also.
Something is very fishy.. And I am very tired after spending half the night on this ;(
