RT-AC86U crashing a few times a day Running 386.7_2
seagull60
I don't know if its coincidence but I recently updated to 386.7_2 and also the modem now crashes a few times a day.
I installed the stock ASUS firmware and then moved back to Merlin but all my settings were still saved so I don't know if I should go through the hassle of a factory reset or this is more likely a hardware issue.
May  5 06:05:07 kernel: nand: Could not find valid ONFI parameter page; aborting
May  5 06:05:07 kernel: brcmboard registered
May  5 06:05:07 kernel: genirq: Flags mismatch irq 36. 00000000 (brcm_36) vs. 00000000 (brcm_36)
May  5 06:05:07 kernel: pci 0000:00:00.0: of_irq_parse_pci() failed with rc=-22
May  5 06:05:07 kernel: pci 0000:01:00.0: of_irq_parse_pci() failed with rc=-22
May  5 06:05:07 kernel: pci 0001:00:00.0: of_irq_parse_pci() failed with rc=-22
May  5 06:05:07 kernel: pci 0001:01:00.0: of_irq_parse_pci() failed with rc=-22
May  5 06:05:07 kernel: broadcomThermalDrv brcm-therm: init (CPU count 2 2 2 2)
May  5 06:05:07 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) Link UP 100 mbps full duplex
May  5 06:05:07 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 1000 mbps full duplex
May  5 06:05:07 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) Link UP 10 mbps half duplex
May  5 06:05:07 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
May  5 06:05:07 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) Link DOWN.
May  5 06:05:07 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) Link DOWN.
May  5 06:05:07 kernel: eth0 (Int switch port: 3) (Logical Port: 3) Link UP 1000 mbps full duplex
May  5 06:05:07 kernel: hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
May  5 06:05:10 acsd: selected channel spec: 0x100c (12)
May  5 06:05:10 acsd: Adjusted channel spec: 0x100c (12)
May  5 06:05:10 acsd: acs_set_chspec: 0x100c (12) for reason APCS_INIT
May  5 06:05:14 acsd: selected channel spec: 0xe06a (100/80)
May  5 06:05:14 acsd: Adjusted channel spec: 0xe06a (100/80)
May  5 06:05:14 acsd: acs_set_chspec: 0xe06a (100/80) for reason APCS_INIT
May  5 06:05:14 Mastiff: init
May  5 06:05:14 wsdd2[2000]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
May  5 06:05:17 wsdd2[2000]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
May  5 06:05:20 wsdd2[2000]: Terminated received.
Oct 17 17:59:16 crond[1917]: time disparity of 2336394 minutes detected
Let me know if there's anything else I can post.
Backup your settings and do a full reset and see what happens then. You need to eliminate your settings being the cause. If it works then you know it's your settings, if it doesn't you can always restore the settings from your back up.
