RT-AC86U Errors after latest firmware update (386.14)
mozzarella
Hi All,
during last update I did mistake and hit update button instead of upload file mannualy. It tooks long time to update and in meantime i stop it and tried
to upload new firmware in a standard way. It was not possible even GUI gives me "success" message.
Finaly I did NAVRAM erase using amtm. It not helped but finally I was able to update firmware using asus restoration tool.
After that router is working, navigation is slightly slower and I feel that not all function are working as it should. I see below errors in the system log.
I know that this is EoL product but maybe someone has idea what was broken during Navram erase process.
Thanks!
Jul 26 16:51:58 kernel: UBIFS error (ubi1:0 pid 27738): do_readpage: cannot read page 2 of inode 65, error -22
Jul 26 16:51:58 kernel: UBIFS (ubi1:0): un-mount UBI device 1
Jul 26 16:51:58 kernel: ubi1: detaching mtd10
Jul 26 16:51:58 kernel: ubi1: mtd10 is detached
Jul 26 16:51:58 kernel: ubi1: attaching mtd10
Jul 26 16:51:58 kernel: ubi1: scanning is finished
Jul 26 16:51:58 kernel: ubi1: attached mtd10 (name "misc1", size 8 MiB)
Jul 26 16:51:58 kernel: ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Jul 26 16:51:58 kernel: ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Jul 26 16:51:58 kernel: ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
Jul 26 16:51:58 kernel: ubi1: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Jul 26 16:51:58 kernel: ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Jul 26 16:51:58 kernel: ubi1: max/mean erase counter: 70/28, WL threshold: 4096, image sequence number: 1982616507
Jul 26 16:51:58 kernel: ubi1: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Jul 26 16:51:58 kernel: ubi1: background thread "ubi_bgt1d" started, PID 27818
Jul 26 16:51:59 kernel: UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "nvram", R/O mode
Jul 26 16:51:59 kernel: UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Jul 26 16:51:59 kernel: UBIFS (ubi1:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
Jul 26 16:51:59 kernel: UBIFS (ubi1:0): reserved for root: 0 bytes (0 KiB)
Jul 26 16:51:59 kernel: UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 70AF44BE-3B19-4ECF-B11E-616114B3F8BB, small LPT model
Jul 26 16:51:59 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xc1d4c00
Jul 26 16:51:59 kernel: ubi1 warning: ubi_io_read: error -74 (ECC error) while reading 160 bytes from PEB 22:84184, read only 160 bytes, retry
Jul 26 16:51:59 kernel: ubi1 error: ubi_io_read: error -74 (ECC error) while reading 160 bytes from PEB 22:84184, read 160 bytes
Jul 26 16:51:59 kernel: CPU: 1 PID: 27805 Comm: envrams Tainted: P           O    4.1.27 #2
Jul 26 16:51:59 kernel: Hardware name: Broadcom-v8A (DT)
Jul 26 16:51:59 kernel: Call trace:
Jul 26 16:51:59 kernel: [<ffffffc0000876d8>] dump_backtrace+0x0/0x150
Jul 26 16:51:59 kernel: [<ffffffc00008783c>] show_stack+0x14/0x20
Jul 26 16:51:59 kernel: [<ffffffc0004f99c8>] dump_stack+0x90/0xb0
Jul 26 16:51:59 kernel: [<ffffffc0003447bc>] ubi_io_read+0x16c/0x388
Jul 26 16:51:59 kernel: [<ffffffc000341e28>] ubi_eba_read_leb+0x138/0x440
Jul 26 16:51:59 kernel: [<ffffffc000341134>] ubi_leb_read+0x7c/0xe0
Jul 26 16:51:59 kernel: [<ffffffc000215a50>] ubifs_leb_read+0x38/0xb0
Jul 26 16:51:59 kernel: [<ffffffc0002176ac>] ubifs_read_node+0x9c/0x330
Jul 26 16:51:59 kernel: [<ffffffc0002179fc>] ubifs_read_node_wbuf+0xbc/0x358
Jul 26 16:51:59 kernel: [<ffffffc0002346fc>] ubifs_tnc_read_node+0x44/0x130
Jul 26 16:51:59 kernel: [<ffffffc00021b040>] ubifs_tnc_locate+0x1c8/0x1e0
Jul 26 16:51:59 kernel: [<ffffffc0002128fc>] ubifs_iget+0x8c/0x668
Jul 26 16:51:59 kernel: [<ffffffc00020fd80>] ubifs_lookup+0x108/0x1d8
Jul 26 16:51:59 kernel: [<ffffffc000146ddc>] lookup_real+0x24/0x68
Jul 26 16:51:59 kernel: [<ffffffc00014bc8c>] do_last.isra.13+0x78c/0xc20
Jul 26 16:51:59 kernel: [<ffffffc00014c1a4>] path_openat+0x84/0x5c0
Jul 26 16:51:59 kernel: [<ffffffc00014d7d8>] do_filp_open+0x30/0x98
Jul 26 16:51:59 kernel: [<ffffffc00013d158>] do_sys_open+0x140/0x228
Jul 26 16:51:59 kernel: [<ffffffc0001859ec>] compat_SyS_open+0x1c/0x28
Jul 26 16:51:59 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xc287c00
Jul 26 16:51:59 kernel: ubi1 warning: ubi_io_read: error -74 (ECC error) while reading 870 bytes from PEB 28:30072, read only 870 bytes, retry
Jul 26 16:52:00 kernel: bcm63xx_nand ff801800.nand: uncorrectable error at 0xc287c00
Jul 26 16:52:00 kernel: ubi1 warning: ubi_io_read: error -74 (ECC error) while reading 870 bytes from PEB 28:30072, read only 870 bytes, retry
Jul 26 16:52:00 kernel: ubi1 error: ubi_io_read: error -74 (ECC error) while reading 870 bytes from PEB 28:30072, read 870 bytes
Jul 26 16:52:00 kernel: CPU: 1 PID: 27805 Comm: envrams Tainted: P           O    4.1.27 #2
Jul 26 16:52:00 kernel: Hardware name: Broadcom-v8A (DT)
Jul 26 16:52:00 kernel: UBIFS error (ubi1:0 pid 27805): read_block: bad data node (block 2, inode 65)
Jul 26 16:52:00 kernel:     magic          0x6101831
Jul 26 16:52:00 kernel:     crc            0xfa8eafea
Jul 26 16:52:00 kernel:     node_type      1 (data node)
Jul 26 16:52:00 kernel:     group_type     0 (no node group)
Jul 26 16:52:00 kernel:     sqnum          21061
Jul 26 16:52:00 kernel:     len            1232
Jul 26 16:52:00 kernel:     key            (65, data, 2)
Jul 26 16:52:00 kernel:     size           4006
Jul 26 16:52:00 kernel:     compr_typ      2
Jul 26 16:52:00 kernel:     data size      1184
Jul 26 16:52:00 kernel:     data:
Jul 26 16:52:00 kernel:     00000000: dd 55 c9 6e 22 49 10 e5 53 e6 03 b0 27 33 72 2d a4 3a 18 83 6f a3 91 2c b7 a6 6f 28 57 84 6c 0c
Hi All,
Thanks!
ECC errrors in your flash. This typically indicate a failing flash chip, so it`s a hardware issue.
Or maybe you've just corrupted it by your errant procedures. I've seen brand new flash drives irretrievably corrupted when mishandled too. And nothing I try will typically save it. I just throw it away and chalk it up to a lesson learned.
Thanks for quick reply. I suspected that a replacement would be necessary. Was hoping to wait a while longer and switch to a device with wifi7. Thanks.
