I had a power outage and after that my AC86U router stopped detecting any cable I plug in, at any port, including WAN port.
I can only access the router UI using Wi-Fi.
While testing, by disabling and enabling my PC network adapter, the router logged these messages bellow once for LAN 4, but still showed it as "unplugged".
I'm not sure what that "Deep Green Mode" is but I disabled it using.
I also did completely reset the router but with no avail. It still won't detect any cable. Even Asus restoration tool didn't work.
Is there anything I can do to restore that conectivity?
May 5 02:11:55 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps half duplex
May 5 02:11:55 kernel: <=== Deactivate Deep Green Mode
May 5 02:11:55 kernel: br0: port 1(eth1) entered listening state
May 5 02:11:56 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
May 5 02:11:56 kernel: ===> Activate Deep Green Mode
May 5 02:11:56 kernel: br0: port 1(eth1) entered disabled state
May 5 02:13:06 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 10 mbps half duplex
May 5 02:13:06 kernel: <=== Deactivate Deep Green Mode
May 5 02:13:06 kernel: br0: port 1(eth1) entered listening state
May 5 02:13:07 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
May 5 02:13:07 kernel: ===> Activate Deep Green Mode
May 5 02:13:07 kernel: br0: port 1(eth1) entered disabled state
# pwr config --dgm off
May 5 02:08:01 kernel: <=== Deactivate Deep Green Mode
May 5 02:08:01 kernel: Deep Green Mode feature changed to disabled (DGM status: deactivated)
