RT-AC87U 3.0.0.4.378_4608 Unofficial Beta Firmware
If you look at the realtime Traffic Monitor page, Asus recently added a warning that Traffic Monitoring will be inaccurate if you have NAT acceleration enabled.
Hi RMerlin
hehe, how is that possible. Thanks RMerlin
Note: The wired network traffic bypasses CPU when NAT Acceleration is enabled and may affect Traffic Monitor accuracy. Click HERE to disable NAT Acceleration.
My Traffic Manager - Traffic Monitor (Daily) "bug" was probably because i have my NAT Acceleration on AUTO (enable)
EDIT: 2 days & 12 hours uptime, reboot
I did an reboot of my router.
One bug is the WPS is till enable on the 5Ghz band
I have it also on AUTO...
I disable my NAT Acceleration, and now the Traffic Manager - Traffic Monitor (Daily) seems to count correctly :)
I'm still unable to get some games working with AiProtection enabled.... [emoji22]
The rest is working just perfect.... Don't know why this time is blocking them, when on previous versions was working fine. Hope later builds or final release solve that
Replied through Tapatalk
Has anyone who has this firmware running for more than 24 hrs experiencing
lag? I started to see longer page loads on internet browsing to the point of
being annoying. Anyone else?
Went back to DDWRT page loads are like lightening again.
CC
Hi
What kind of games, maybe we other can test the same games :)
CC
Yes. I also had trouble with lag on some devices about 24 hours after flashing this firmware. I went to DD-WRT for the first time last night. Time will tell, but so far DD-WRT seems really good.
Hi
Mainly with Evolve, the others such as Battlefield 4 I can play them but after a minute or two gets disconnected because of not receiving UDP packets. I'm suspecting is more lag related with the router causing timeout. Because turning off Aiprotection it goes just perfect.
I'll have to test it without the router to validate if UDP's are getting blocked
OK, did some testing, turning ON/OFF solved the 5G WPS... Now it looks OFF both bands.
Yes until you reboot your router, is goes enable again on 5Ghz band
Thanks, I do have BF4. Going to test it later and see if I also get disconnected.
EDIT
I was just playing BF4 for about 1 hour, no disconnection
I have also gone over to DD-WRT for the first time and intend to keep using it, at least for now. The only issue I am having is getting the stupid DirecTV Internet connection kit to work. However, the Internet performance is such that it is well worth taking the time and effort to figure this out.
What version of DDWRT are you using?
CC
