rt-ac87u antenna orientation theories?
Something tells me that a dipole needs two poles.
Not sure how they could guarantee that there would be a ground-plane under it if they were end-fed. Seems like that would be kind of a problem for people that didn't set the device on a couple square-feet of metal.
I just always assumed that the connector on the end fed some transmission-line to the middle of the plastic antenna-assembly, and there was a dipole leg from there to each end. At 12cm = lambda for the 2.4GHz band, the length seems to be about right for that to be the case - yes?
Can't say that I've ever cracked one open to see if that is what's inside though.
73's
Good Morning from Germany
My config 9db Antenna for 2,4 and 5,0 Mhz
Thus is what Asus support sent me for RT-AC87U. \||/
