RT-AX58U and crossover cables
mgoblue62
I just went through a very frustrating experience with this new router. My old Asus RT-AC68U had started to behave oddly - losing internet or just plain locking up. So I backed up the configuration and restored to a new RT-AX58U. This whole process worked great, but one device that was connected to one of the four LAN ports wouldn't get an IP address. I spent way too much time trying various fixes until I finally figured out that the Ethernet cable that I was using all this time was a "crossover cable". The RT-AC68U and *many* other routers had been fine with this, but not the new RT-AX58U(!) After I exchanged the crossover cable for a regular one, all was well.
Is there a software option that would permit the RT-AX58U to accept a crossover cable (if I wanted to use it in a pinch)? Is there a reason why Asus would change the switch hardware so that it behaves differently from the many ASUS routers I have used in the past?
Thanks!
You should never take a backup from one router and restore it onto another especially if they're different models. That is not the intended purpose of the Asus backup file.
Ethernet crossover cables shouldn't be used when connecting a terminal device to a switch (the crossover is done within the switch).
