I have a RT-AX86U (3.0.0.4.388_22525) with two Ai-Mesh nodes RT-AX59U (3.0.0.4.388_31345) and RP-AX56 (3.0.0.4.386_42860).
Last few days I'm having a lot of problems. AX86U would reboot, most often a dozen times in row.
Tried disconnecting everything but for some reason it doesn't help.
Does anyone know what might be the problem?
Full log is attached, small sample following below.
May 5 07:05:09 crashlog: LOG
May 5 07:05:09 crashlog: <6>pci 0001:01:00.0: BAR 4: assigned [mem 0xd0c00000-0xd0cfffff 64bit pref]
May 5 07:05:09 crashlog: <6>pci 0001:01:00.0: BAR 0: assigned [mem 0xd0800000-0xd080ffff 64bit]
May 5 07:05:09 crashlog: <6>pci 0001:00:00.0: PCI bridge to [bus 01]
May 5 07:05:09 crashlog: <6>pci 0001:00:00.0: bridge window [mem 0xd0000000-0xd0bfffff]
May 5 07:05:09 crashlog: <6>pci 0001:00:00.0: bridge window [mem 0xd0c00000-0xd0cfffff 64bit pref]
May 5 07:05:09 crashlog: <6>pcieport 0001:00:00.0: enabling device (0000 -> 0002)
May 5 07:05:09 crashlog: <6>pcieport 0001:00:00.0: Max Payload Size set to 512/ 512 (was 128), Max Read Rq 512
May 5 07:05:09 crashlog: <6>pci 0001:01:00.0: Max Payload Size set to 512/ 512 (was 128), Max Read Rq 512
May 5 07:05:09 crashlog: <4> bcm963xx-pcie: [2] DT node available: /pcie@80060000
May 5 07:05:09 crashlog: <4> bcm963xx-pcie: found port [2] GEN2 Core Rev [3.04] with 1 Lanes^M
May 5 07:05:09 crashlog: <4>getrcal for res select 5, int 665, ext 622, ratio 119 ratio1 164, rcal 10
May 5 07:05:09 crashlog: <4> bcm963xx-pcie: Core [2] setting resistor calibration value to 0xa
May 5 07:05:09 crashlog: <4> bcm963xx-pcie: core [2] link is DOWN^M
May 5 07:05:09 crashlog: <4> bcm963xx-pcie: core [2] powered down^M
May 5 07:05:09 crashlog: <4>^[[1m^[[34mWifi Forwarding Driver is initialized!^[[0m
May 5 07:05:09 crashlog: <6>bcmspu: loading driver
May 5 07:05:09 crashlog: <2>broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
May 5 07:05:09 crashlog: <4>brcm_otp_init entry
May 5 07:05:09 crashlog: <5>ubi2: attaching mtd10
May 5 07:05:09 crashlog: <5>ubi2: scanning is finished
May 5 07:05:09 crashlog: <5>ubi2: attached mtd10 (name "misc1", size 8 MiB)
May 5 07:05:09 crashlog: <5>ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
May 5 07:05:09 crashlog: <5>ubi2: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
May 5 07:05:09 crashlog: <5>ubi2: VID header offset: 2048 (aligned 2048), data offset: 4096
May 5 07:05:09 crashlog: <5>ubi2: good PEBs: 63, bad PEBs: 1, corrupted PEBs: 0
May 5 07:05:09 crashlog: <5>ubi2: user volume: 1, internal volumes: 1, max. volumes count: 128
May 5 07:05:09 crashlog: <5>ubi2: max/mean erase counter: 16/6, WL threshold: 4096, image sequence number: 1725884149
May 5 07:05:09 crashlog: <5>ubi2: available PEBs: 0, total reserved PEBs: 63, PEBs reserved for bad PEB handling: 3
May 5 07:05:09 crashlog: <5>ubi2: background thread "ubi_bgt2d" started, PID 379
May 5 07:05:09 crashlog: <5>UBIFS (ubi2:0): background thread "ubifs_bgt2_0" started, PID 394
May 5 07:05:09 crashlog: <5>UBIFS (ubi2:0): UBIFS: mounted UBI device 2, volume 0, name "nvram"
May 5 07:05:09 crashlog: <5>UBIFS (ubi2:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
May 5 07:05:09 crashlog: <5>UBIFS (ubi2:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1396736 bytes (1 MiB, 11 LEBs)
May 5 07:05:09 crashlog: <5>UBIFS (ubi2:0): reserved for root: 0 bytes (0 KiB)
May 5 07:05:09 crashlog: <5>UBIFS (ubi2:0): media format: w4/r0 (latest is w4/r0), UUID 4B2A44DD-417E-46D8-97CE-24D278768884, small LPT model
May 5 07:05:09 crashlog: <5>UBIFS (ubi2:0): un-mount UBI device 2
May 5 07:05:09 crashlog: <5>UBIFS (ubi2:0): background thread "ubifs_bgt2_0" stops
May 5 07:05:09 crashlog: <5>ubi2: detaching mtd10
May 5 07:05:09 crashlog: <5>ubi2: mtd10 is detached
May 5 07:05:09 crashlog: <5>random: init urandom read with 6 bits of entropy available
May 5 07:05:09 crashlog: <4>jffs2: Empty flash at 0x012d78ac ends at 0x012d8000
May 5 07:05:09 crashlog: <4>jffs2: Empty flash at 0x022aa9dc ends at 0x022ab000
May 5 07:05:09 crashlog: <4>jffs2: Empty flash at 0x022b91a8 ends at 0x022b9800
May 5 07:05:09 crashlog: <4>jffs2: Empty flash at 0x02c2f5e0 ends at 0x02c2f800
May 5 07:05:09 crashlog: <4>Loading HND Module
May 5 07:05:09 crashlog: <4>crossbar[0]: del cb_idx=0 ext_ep=0 SERDES:6
