RT-AX86U Hard Factory Reset not fully working
I have had mine since mid March 2021. It does not have an Asus branded power supply. It is marked AcBel.
DarkKnight75, climb on your mountain bike and give the AX86U another try,
Yes, i may go for a ride after work and i may pick up another....
At that price, I would grab one, if only I had a nearby MicroCenter. FYI, BestBuy still wants $280 for that model, and $250 for the inferior RT-AX86S.
RT-AX86U dirty upgrade from Beta1 to Beta2 smooth, no issues on syslog or any strange behaviour
After doing a second full reset a couple of days ago (through the GUI), the router rebooted on its own with internet at the same time. Could this be a firmware related bug to drivers?
I am seeing some of these messages below
kernel: httpd (1541): drop_caches: 1
Hi @DarkKnight75, hi all
do you know what this “kernel: httpd (xxx ): drop_caches: 1” message mean?
EDIT:
found the answer to my own question:
http://www.snbforums.com/threads/386-4-alpha-build-s-testing-available-build-s.74186/post-722204
