Solved RT-AX88 386.8 with RP-AX56 no System-wide Guest Network
ankhazam
Hi I'm running the setup as in title:
* single RT-AX88U@386.8
* a few RP-AX56@3.0.0.4.386_42862 as Ai-Mesh nodes
* have configured Guest Network #2 @2.4GHz
and these are my settings:
The issue is that according to
1) https://www.asus.com/support/FAQ/1045327/
2) https://dongknows.com/asus-rp-ax56-ax1800-dual-band-repeater-review/
The repeaters are also supposed to broadcast my Guest network but I cannot find the broadcast setting described in source #1 :(
Am I doing something wrong?
Best regards,
Ank
It is unclear whether you are using the RP-AX56 as a repeater or an AiMesh extender. Which is it?
When you say "broadcast setting" do you mean the "Sync to AiMesh node" option? If so, that option is only available on guest network index #1.
As AiMesh Nodes
Ok... Then I need to move it to GN#1...
Thank you!
