RT AX88U and AX58U Aimesh wired backhaul, no 5ghz network on node (AX58U)
deuscreator
Hey Folks,
I have been reading the forum and seen that some of you had similar problems, but not exactly this: I have an AX88U as my main router and an AX58U as a node, with an exclusively wired backhaul setting (backhaul connection priority set to 1G WAN only). Nevertheless, I cannot enable the 5ghz wifi on the node, it just shows up as N/A in the settings, and as a wifi network named "ASUS" if I do a search for available networks on a computer.
Any ideas? Theoretically, dedicated wireless backhaul should not be established here, when we are talking about two dual-band routers...
Thanks in advance!
