MaverickPenguinX
I recently upgraded from a 68U which was rock solid, and ran scripts fairly well despite having a much slower CPU. The 68U rarely needed a restart, despite having it for years and constantly tinkering with it. But this new RT-AX88U seems to be having some stability issues that I can't shake, despite having reset and trying a few different firmwares.
With the last stable firmware of Merlin (384.14)I was able to install diversion and skynet without any issues. However every day without having changed any router settings, with the network basically at rest, I would find all 4 cores on the CPU maxed out at 99% and when I would ssh in and run top I would see about 7 instances of diversion running. After unplugging and restarting the router the CPU usage would trickle down to almost 0% on all cores.
I reset the router and upgraded the firmware to the new 384.15alpha and while I don't see the miraculous jump to 99% usage, I am seeing a consistent build up. Yesterday the cores were consistently at about 30% which I knew was an issue because when the router is functioning normally the core values are different and tend to shift. So I've just been watching the cores since yesterday and as of 2 hours ago they were at 86%, and now they're at 92%. After SSH and running tops I have spotted 4 instances of diversion running.
Anyone got any advice or solutions?
