RT-AX88U snmpd - mini Guide
You need something that can read SNMP to test
Thanks for the reply.
It doesn't look like it's working:
I recall something was not documented correctly about the confg file location. Do some searching
@Skeptical.me What is it that you think isn't working?
You said a few posts back that you got it working. Your were able to snmpwalk it. Your Nagios program could see it and your image in post #62 shows it working.
Oh, okay ... I wasn't sure. I'm just learning about snmp and Cacti/Nagios so there are a lot of things I don't understand yet.
Thanks for your reply.
The last image I posted had a column that says snmp, and all the devices (apart from the router and printer) say "Down" , so I assumed that meant snmp wasn't working.
SNMP only reports information about the machine it's running on (i.e. your router). If you want other machines to report SNMP data they need to be running their own SNMP service.
Ahh, right. I had assumed snmp on the router reported the devices connected. Total noob lol ... thanks!
as discused in this thread f the normal snmpd crashed on the RT-AX88U.
So i tryed the mini-snmp package from entware, wich runs totally fine. Just want to share, if someone need this.
install mini_snmpd, snmp-utils
opkg install mini_snmpd
opkg install snmp-utils
create /opt/etc/init.d/S50mini_snmpd
#!/bin/sh
ENABLED=yes
PROCS=mini_snmpd
ARGS="-i br0,eth0 -D RT-AX88U -L YOUR-LOCATION -c public -C YOUR-EMAIL"
PREARGS=""
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/opt/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
add/replace your Interfaces in the script after -i and replace YOUR-LOCATION and YOUR-EMAIL with your values.
test from different linux pc with installed snmp
 snmpwalk -v2c -c public 192.168.X.X
grafana:
Hi Help, please.
by the site "https://openwrt.org/toh/asus/start" , OpenWrt not support "ASUS RT-AX88U". So how did you manage to run commands like this : "opkg install mini_snmpd" ?
10x
I got bitten by this change as well, I realized just now, with snmpd broken in my install for the last month and a half since I did an opkg update.
To make a long story short, the new mini-snmpd works perfectly but it needs some help
1) the old configuration you had in /opt/etc/init.d/S50mini_snmpd (in the "ARGS" variable)_ is now completely ignored, I found that out the hard way. S50... is still used to start / restart the daemon though.
2) the new configuration goes in /opt/etc/mini-snmpd.conf. Here you configure your community string and the interfaces that you want to expose via snmp, by default, it does not expose ANY interface. You can inspect what interfaces your router has configured by typing ifconfig. If you just want the WAN (internet connection) traffic then you want "eth0", with that, remove the "#" prefix in the "iface-table" line, and adjust the interface list according to what you want
iface-table = { "br0", "eth0" }
Basically that's all you need to do in this file, no need to make any other change unless you know what you are doing
3) restart the daemon
/opt/init.d/S50mini_snmpd restart
4) test it:
snmpwalk -v 2c -c public -Of localhost .1
you will notice that 64 bit counters are now supported which is nice
YMMV but this worked for me, no need to downgrade mini-snmpd versions
I've updated 1.6-1 to 1.6-3, and edited the conf file but cannot restart the daemon.
I see a /opt/init.d/S50mini_snmpd not found error.
This does not respond to any commands:
admin@RT-AX88U-4680:/tmp/mnt/rtax88u/entware/etc/init.d# ls
S50mini_snmpd rc.func rc.unslung
Thanks in advance for any help!
The restart command is wrong. It should be:
/opt/etc/init.d/S50mini_snmpd restart
Or just reboot the router.
Also, for AX88U I would recommend installing regular snmpd from Entware instead of mini_snmpd, unless you have a specific reason for it.
RT-AX88U stopped crashing with snmpd two years ago starting with firmware 386.8, and works fine with current 3004.388.7 as well.
Thanks, I wasn't aware.
I've removed the mini_snmpd package and installed the snmpd and snmp-utils packages.
I'm stuck as to how to configure and where to save the files; searching the site hasn't been entirely clear.
Yeah, it's a bit tricky to get it running. Below is how I set up snmpd from scratch on my RT-AX88U router and on the AiMesh nodes as well.
Installation​
1. Install entware from amtm
2. install the snmpd and snmp-utils packages
Configuration​
1. Edit /opt/etc/init.d/S47snmpd and clear the ARGS content. For some reason it doesn't work with it. Effectively you want the following contents of S47snmpd
Bash:
#!/bin/sh
ENABLED=yes
PROCS=snmpd
ARGS=""
PREARGS=""
DESC=$PROCS
2. Create or replace /opt/etc/snmp/snmpd.conf with the following basic contents
agentAddress  udp:161
rocommunity public default
sysName RT-AX88U
sysLocation LivingRoom
sysContact your_email
Testing​
Start snmpd:
/opt/etc/init.d/S47snmpd restart
Check if it's running:
/opt/etc/init.d/S47snmpd check
Check response (assuming this is your router's IP)
snmpwalk -c public 192.168.1.1
Further actions​
Tweak snmpd.conf to e.g. limit monitored interfaces, or to enhance security by removing public community, adding users and passwords, enabling SNMPv3 if your client allows, etc.
Or if you're just running a small home LAN, just leave it as it is and call it a day. :)
Installation​
Configuration​
Bash:
#!/bin/sh
ENABLED=yes
PROCS=snmpd
ARGS=""
PREARGS=""
DESC=$PROCS
sysName RT-AX88U
Testing​
Start snmpd:
Further actions​
Spectacular, thank you so much, very much appreciated! I was lost in a sea of either subtly or very different snmpd.conf files!
One last question, if I may, do I need to do anything in terms of my USB stick / JFFS?
Thanks Slayer for the info, still useful in 2026! Installed on my RT-AX88U as well. For those finding this now, here is some additional info and remarks.
By testing snmpd at the command line (snmpd -h is your friend!), I found that if you put -C first, it works. This will prevent snmpd from trying to read the default configuration files, which would find the same config file a second time. This also makes sure that all the snmpd conf is in one place, and that there is not some other conf file changing settings unexpectedly.
ARGS="-C -c /opt/etc/snmp/snmpd.conf"
# snmpd -h
  -C do not read the default configuration files
       (config search path: /opt/etc/snmp:/opt/share/snmp:/opt/lib/snmp:/root/.snmp)
I believe that this config will make your SNMP agent available on the WAN interface! In combination with the default port and well-known community string, this means that your SNMP router data is freely available to anyone.
I haven't actually tested the hypothesis, but RTRMON (Thanks @Viktor Jaep!) shows the open UDP port (Page 5/7):
The fix is to add your router hostname in the agentAddress: udp:router_hostname:161
Once you change /opt/etc/snmp/snmpd.conf, run /opt/etc/init.d/S47snmpd restart, then refresh your (D)iagnostics in RTRMON, you should no longer see snmpd listening on the WAN port:
Now, if I could just get ports 5353 (avahi-daemon) & 67 closed, I'd be glad. Anybody can point me in the right direction? (in PM, to not derail this thread!)
To summarize and for reference, here are my current config files:
# cat /opt/etc/init.d/S47snmpd
     #!/bin/sh
     ENABLED=yes
     PROCS=snmpd
     # References:
     # SNMPD Man page:  http://www.net-snmp.org/docs/man/snmpd.html
     # snmpd.conf page: http://www.net-snmp.org/docs/man/snmpd.html
     # SNBForums post:  https://www.snbforums.com/threads/rt-ax88u-snmpd-mini-guide.56354/page-4#post-910985
     # -c FILE: Read FILE as a configuration file
     # -C: Do not read any configuration files except the ones optionally specified by the -c option
     PREARGS=""
     DESC=$PROCS
# cat /opt/etc/snmp/snmpd.conf
     agentAddress udp:[--put_your_router_hostname_here--]:161
     rocommunity [--REDACTED--] default
     sysName RT-AX88U
     sysLocation [--REDACTED--]
     sysContact [--REDACTED--]
Hope this can helps others!
Dan.
