Two 68U's, one in DHCP mode the set up as WAP. Got a rescue-mode scenario on the WAP with last FW upgrade, sorted it out - but I'm guessing what's happened is that current FW demands (as now stated on WebGUI) "Note: The function only support [Open System/NONE, Open System/WEP] security authentication method."
Well - it worked fine prior (WPA2, same SSIDs, 5GHz bridge, 2.4GHz WAP) with "hybrid" setting & respective MACs correctly specified as "connect-to" points - despite WPA2. Current status: Wireless simply not connecting on WAP unit, as if it has not recovered correct IP address (or) simply cannot handle WPA2.
Any ideas? Scenario: need a wireless-connected wireless repeater. What's the best way (now)?
/Schooner
/Schooner
