RT87U no permannet OC ?
netguru
i oc with:
nvram set clkfreq=1200,800
nvram commit
then i check the settings and get 1200 mhz, in webui and per nvram check. Router works fine ...
But after rebooting the value is still 1000 mhz ...
Any idea?
I am under RT-AC87U, 380.57_alpha4-gb5eb46f, Bootloader 1.0.3.2.
New ASUS FW binary blobs are the reason for that happening and its not a model specific, it happens on all models using latest FW version.
Hm, okay.
should be solved by using a script workaround?
That is my idea:
#!/bin/sh
sleep 4
nvram commit
chmod a+rx /jffs/scripts/services-start
Yes script will work.
