RTAC66U OpenVPN over 443
spotopolis
I currently have openVPN setup and working on my router with the latest firmware. I have it running on the default 1194. I want to set it up to use 443. I changed it to tcp 443 and exported the new settings. The client tries to connect but then it times out(?) And I get a ping restarting error. And am not actually connected. What am I missing?
Port 443 might be conflicting with AiCloud. Make sure AiCloud is disabled.
Everything under AiCloud 2.0-> AiCloud 2.0 is disabled. The only option on is under AiCloud 2.0-> Settings "enable password protection feature" should that be off as well? I didn't think that would matter since AiCloud is off.
Edit:I tried shutting off the password protection. Rebooted the router and client. Still did not work. It acts like it connects. Says connection successful, then I get the ping restarting error again.
