and the AC86U, alsoToday, the RT-AX58U, RT-AC86U, RT-AX88U, and RT-AC86U are the only rational choices.![]()
Post above from @L&LD is exactly correct ... but here's an interesting thing ...Random question - my RT-AX82U has been running on firmware version 3.0.0.4.386_41700 for quite a while now, possibly ever since i bought it in January. Does this mean that the transition to the 386 codebase from Asus has now happened? Maybe Merlin support for this model now.... possbibly, maybe..... pls?![]()
Asuswrt firmwares are model-specific. You cannot run a firmware for one model on a different one.so although his firmware will NOT run "as is" on your RT-AX82U - there may be a work-around at some point in the future?
Isn't RT-AC2900 "same as" RT-AC86U, yet we still got merlin for it, but i guess that's just marketing "rename", 82u isn't just a rename of the router.Asuswrt firmwares are model-specific. You cannot run a firmware for one model on a different one.
you are wrong82u isn't just a rename of the router.
If it is just a rename, then why can't we run merlin on it ? it has the same hardware except RGB lights ?you are wrong
Clip2Net — screen capture tool for Windows, Android, iPad, Mac, Linux
Clip2net — most popular image sharing toolclip2net.com
RTAXJ300 AX3000 Dual Band Wi-Fi Router, AX5400 Dual Band Wi-Fi Router, Dual Band Wi-Fi Router RF Exposure Info MPE Report ASUSTeK Computer
AX3000 Dual Band Wi-Fi Router, AX5400 Dual Band Wi-Fi Router, Dual Band Wi-Fi Router MPE Report details for FCC ID MSQ-RTAXJ300 made by ASUSTeK Computer Inc. Document Includes RF Exposure Info MPE Reportfccid.io
That RGB controller is additional hardware, so obviously NOT the same hardware.it has the same hardware except RGB lights ?
transformation is possibleIf it is just a rename, then why can't we run merlin on it ? it has the same hardware except RGB lights ?
I'll test it now.Hi,
Yesterday i released an RT-Ax82U build that at moment doesn't have any known Major issue.
If interested, you can find the images at https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/rt-ax82u-latest.
Enjoy
Welcome To SNBForums
