scMerlin scMerlin v2 - Service and script control menu for AsusWRT-Merlin
when things are broke i like to fix ASAP :)
it helped that today is a late shift at work so i had time in the morning to get it fixed!
Late shift? People, please buy the man some more coffee. Coding requires caffeine!
Web UI doesn't seem to appear after updating. And when I run scmerlin from the CLI there's this message:
WebUI for scMerlin is available at:
WebUI page not found
Things I've tried so far to bring back the web UI:
- Uninstall, reboot, install
- Force update
- Uninstall, delete user2.asp & user2.title under /tmp/var/wwwext, then install via amtm/cURL
- Turning off and on scmerlin's USB features
- Listing webpage mounts in scmerlin, with menu option w (doesn't list user2.asp)
- Hard refresh after every installation/reinstallation
Installation scripts says it's mounting the web UI as user2.asp, it does create the files but doesn't mount.
I'm totally lost here, any ideas?
- Force update
that would mean it's not being added to /tmp/menuTree.js
which other Addons are you running?
@Jack Yaz Just updated to 2.2.1 and something has broken again! o_O
It looks like they're mounting in the logs, but only getting Connmon, NtpMerlin and spdMerlin in the webgui. This is on my AX88U. I've rebooted after updating scMerlin and done another 3 reboots after trying a couple of things and getting the same outputs.
EDIT - I'm using safari
can you share a syslog copy? also output of:
grep user /tmp/menuTree.js
everything loading properly on my 86U and 68U :(
are you running the stable or develop FlexQos?
syslog - https://pastebin.com/ja3KEgm6
{url: "user1.asp", tabName: "CakeQOS-Merlin"},
{url: "user2.asp", tabName: "FlexQoS"},
{url: "user3.asp", tabName: "connmon"},
{url: "user4.asp", tabName: "ntpMerlin"},
{url: "user5.asp", tabName: "spdMerlin"},
if(userRSSI_support){
Guessing Stable as I've just re-installed it and come off CAKE, wanted to test it again as the congestion in my area seems to have calmed down now.
have you checked everything is up to date, use amtm for most, modmon manually.
modmon and scmerlin show as mounting as 6 and 7...so not sure where they've gone
I always forget about modmon with it not being in the amtm menu!! o_O
Nail on the head once again Jack.. Updated modmon and rebooted (twice, just to be sure!) and it's resolved again.
Many thanks
Yesterday the same happened to me with the pages not being mounted. However, they were on the menu tree file.
A reboot fixed the issue, after updating all the addons
What output do you get from grep redirect /tmp/menuTree.js
JavaScript:
{url: "javascript var helpwindow=window.open('/javascript var helpwindow=window.open('/ext/shared-jy/redirect.htm','_blank')','_blank')", tabName: "Help & Support"},
PS: I needed to remove ":"s from "javascript:" since forum doesn't allow me to paste those.
can you check all scripts are up to date using amtm? you may also need to reboot since the Addons tab was changed to fix a firefox issue
Yes, everything seems up to date, however, it caught my attention that uiDivStats also struggles to generate stat graphics (numbers are fine tho).
I'll reboot once more and let you know.
JavaScript:
Ok, after a reboot scmerlin web UI seems to work again, uiDivStats is still buggy but that's a problem to be discussed in another topic. Sorry for the inconvenience and thanks for your great work.
function show_memcpu(){
    document.getElementById("mem_total_td").innerHTML = mem_stats_arr[0] + " MB";
    document.getElementById("mem_free_td").innerHTML = mem_stats_arr[1] + " MB";
    document.getElementById("mem_buffer_td").innerHTML = mem_stats_arr[2] + " MB";
    document.getElementById("mem_cache_td").innerHTML = mem_stats_arr[3] + " MB";
    if(parseInt(mem_stats_arr[5]) == 0){
        document.getElementById("mem_swap_td").innerHTML = "<span>No swap configured</span>";
    else{
        document.getElementById("mem_swap_td").innerHTML = mem_stats_arr[4] + " / " + mem_stats_arr[5] + " MB";
        document.getElementById("nvram_td").innerHTML = round(mem_stats_arr[6]/1024,2).toFixed(2) + " / " + nvramtotal + " KB";
        document.getElementById("jffs_td").innerHTML = mem_stats_arr[7];
Are my NVRAM and JFFS values destined to be eternally trapped in an "else" block due to not having a swap file? :)
Many thanks for all the time and effort you manage to find that keeps bringing us new toys to play with!
  • Like
Reactions: pdc
I really like the 'WebUI Addons' section, but the links included are http, whereas I am using https, so they don't work (they redirect to the login page). Any chance you can match the protocol to that used to access the page?
I also have a question about the Addons page itself, is there any way to set the order of the tabs in that page? It seems that the order changes every once in a while which throws me off a bit. Not a big problem, just wondering.
Very handy utility, thanks!
Do you have https only, or both, set? I'm pretty sure i used some of Dave's code to get the web urls
  • Like
Reactions: pdc
