I think this is Broadcom's wireless service for automatic channel selection. If so that is really weird.I believe it has to do with if something is being written to the hard drive
EDIT: @Butterfly Bones beat me to it.
What happens when you eject the USB disk? In my case it ends all logging [syslog.log in the webgui stays totally blank after the "### Top of Log File ###" line].
Re-insert USB - does Syslog-ng start automatically? and if so - are you getting all logging activity which was not displayed while USB ejected back in Sylog.log [or in "messages" file? In my case- for e.g. there is no sign of the log entry confirming that the USB was safely ejected ... although it was.
Fully agree that when Scribe runs it is stable and doing a great job [see my specs in signature] - just gets a bit wobbly when stopped as described.
You aren't by any chance using the system() source we experimented with a few months ago? If on alpha2 acsd is spamming the log through its own logging maybe system() is picking it up from two places.If I uninstall scribe, I dont have the issue at all. So I am thinking it has to do with issues cause at the moment it launches something causes acsd to go crazy and never settle down.
Yeah, that would expected behavior until I implement a stop function in scribe. Just never thought about people ejecting the USB. LOLWhat happens when you eject the USB disk? In my case it ends all logging [syslog.log in the webgui stays totally blank after the "### Top of Log File ###" line].
Shouldnt it stop on its own using entware stop services.Yeah, that would expected behavior until I implement a stop function in scribe. Just never thought about people ejecting the USB. LOL
No, I discontinued that a long time ago. Well before v2.0I just downloaded scribe 2 days ago and have been running it with 384.12 alpha 2 every since so idk.
Well yeah, but it won't restart syslogd or klogd. I have to have a think about that.Shouldnt it stop on its own using entware stop services.
Not 100% sure what you mean by this ... there is no filter included to send ascd messages to their own log file, so they would go in main "messages" file. Or are none appearing when ascd is not running at ~100% CPU?It does not appear to be logging my ascd inside scribe though. I am seeing them in regular system log.
A power off fixed it, probably cleared something that was causing reboot hang issues. Cpu is now to normal after loading everything on reboot. I am so glad I do not have to remove your awesome script.What ultimately fixed it? Last post I saw a power off / power on only "fixed" it until you re-booted?
I am not sure what caused it but it is 100 percent fixed.Not 100% sure what you mean by this ... there is no filter included to send ascd messages to their own log file, so they would go in main "messages" file. Or are none appearing when ascd is not running at ~100% CPU?
Can I suggest that you post here your /opt/etc/logrotate.conf file, and the files in your /opt/etc/logrotate.d directory? Or PM them to @cmkelley ? Particularly the A00global file.
I'm thinking there might be something in the call to killall that is messing this up.
Noted @L&LD ... however I have experienced corrupted USB flash drives after simply pulling the power plug - some recovered [disk-check] others didn't - so I'm a bit OCD about "Safely Eject"I have no reason to eject the USB drive so far.
I may give that a try when 384.12 goes final and I do an M&M Config on my network (lots of experimenting these last few weeks).
If I needed to disconnect the USB drive, I would pull the power plug from the router (and not from the AC wall socket) and remove it then (if I needed to do so to upgrade firmware, for example). Safely ejecting it is not the same thing, ime.![]()
Welcome To SNBForums
