Wireguard Session Manager - Discussion (2nd) thread
E:Option ==> diag
        WireGuard VPN Peer Status
interface: wg21
  public key: FSRDl
  private key: (hidden)
  listening port: 51820
peer: TB3Cv
  preshared key: (hidden)
  allowed ips: 10.50.1.2/32
interface: wg11
  public key: SM
peer: RR93
  endpoint: 192..xxx.xxx.xxx:1443
  allowed ips: 0.0.0.0/0
  persistent keepalive: every 25 seconds
        WireGuard VPN Peers
        Peers (Auto=P - Policy, Auto=X - External i.e. Cell/Mobile)
Server  Auto  Subnet        Port   Annotate
wg21    Y     10.50.1.1/24  51820  # RT-AX88U Server #1
Client  Auto  IP               Endpoint              DNS      MTU  Annotate
wg11    N     10.13.53.185/24  192.xxx.xxx.xxx:1443  1.1.1.1       # TorGuard WireGuard Config
Device              Auto  IP            DNS            Allowed IPs  Annotate
Chewie_iPhone12Pro  X     10.50.1.2/32  64.71.255.204  0.0.0.0/0    # Chewie_iPhone12Pro "Device"
        DEBUG:  Routing info MTU etc.
33: wg21: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
    link/none
    inet 10.50.1.1/24 scope global wg21
       valid_lft forever preferred_lft forever
34: wg11: <POINTOPOINT,NOARP> mtu 1420 qdisc noop state DOWN group default qlen 1000
    link/none
    inet 10.13.53.185/24 scope global wg11
        DEBUG:  Routing Table main
10.50.1.0/24 dev wg21 proto kernel scope link src 10.50.1.1
        DEBUG:  RPDB rules
0:      from all lookup local
9810:   from all fwmark 0xd2 lookup 210
10010:  from 192.168.5.103 lookup main
10011:  from 192.168.5.109 lookup main
10012:  from 192.168.56.0/24 lookup main
10013:  from 192.168.50.0/24 lookup main
10014:  from 192.168.224.0/24 lookup main
32766:  from all lookup main
32767:  from all lookup default
        DEBUG:  Routing Table 121 (wg11) # TorGuard WireGuard Config
192.168.5.0/24 dev br0 proto kernel scope link src 192.168.5.1
        DEBUG: Netstat
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
10.50.1.0       0.0.0.0         255.255.255.0   U         0 0          0 wg21
        DEBUG: UDP sockets.
udp        0      0 0.0.0.0:51820           0.0.0.0:*                           -
udp        0      0 :::51820                :::*                                -
        DEBUG:  Firewall rules
        DEBUG:  -t filter
Chain FORWARD (policy DROP 0 packets, 0 bytes)
num   pkts bytes target     prot opt in     out     source               destination
1        0     0 ACCEPT     all  --  *      wg21    0.0.0.0/0            0.0.0.0/0            /* WireGuard 'server' */
2        0     0 ACCEPT     all  --  wg21   *       0.0.0.0/0            0.0.0.0/0            /* WireGuard 'server' */
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
1        0     0 ACCEPT     all  --  wg21   *       0.0.0.0/0            0.0.0.0/0            /* WireGuard 'server' */
2        0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:51820 /* WireGuard 'server' */
Chain OUTPUT (policy ACCEPT 1086 packets, 190K bytes)
        DEBUG:  -t nat
Chain PREROUTING (policy ACCEPT 110 packets, 22021 bytes)
1        2   123 WGDNS1     udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:53 /* WireGuard 'client1 DNS' */
2        0     0 WGDNS1     tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:53 /* WireGuard 'client1 DNS' */
3        0     0 ACCEPT     udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:51820 /* WireGuard 'server' */
Chain POSTROUTING (policy ACCEPT 1 packets, 68 bytes)
1        0     0 MASQUERADE  all  --  *      wg11    192.168.5.0/24       0.0.0.0/0            /* WireGuard 'client' */
Chain WGDNS1 (2 references)
1        1    62 DNAT       all  --  *      *       192.168.5.0/24       0.0.0.0/0            /* WireGuard 'client1 DNS' */ to:1.1.1.1
        DEBUG:  -t mangle
Chain FORWARD (policy ACCEPT 111 packets, 22351 bytes)
1        0     0 MARK       all  --  *      wg11    0.0.0.0/0            0.0.0.0/0            /* WireGuard 'client' */ MARK xset 0x1/0x7
2        0     0 TCPMSS     tcp  --  wg11   *       0.0.0.0/0            0.0.0.0/0            tcpflags: 0x06/0x02 /* WireGuard 'client' */ TCPMSS clamp to PMTU
3        0     0 TCPMSS     tcp  --  *      wg11    0.0.0.0/0            0.0.0.0/0            tcpflags: 0x06/0x02 /* WireGuard 'client' */ TCPMSS clamp to PMTU
4        0     0 MARK       all  --  *      wg21    0.0.0.0/0            0.0.0.0/0            /* WireGuard 'server' */ MARK xset 0x1/0x7
5        0     0 TCPMSS     tcp  --  wg21   *       0.0.0.0/0            0.0.0.0/0            tcpflags: 0x06/0x02 /* WireGuard 'server' */ TCPMSS clamp to PMTU
6        0     0 TCPMSS     tcp  --  *      wg21    0.0.0.0/0            0.0.0.0/0            tcpflags: 0x06/0x02 /* WireGuard 'server' */ TCPMSS clamp to PMTU
Chain PREROUTING (policy ACCEPT 280 packets, 58013 bytes)
1        0     0 MARK       all  --  wg11   *       0.0.0.0/0            0.0.0.0/0            /* WireGuard 'client' */ MARK xset 0x1/0x7
2        0     0 MARK       all  --  wg21   *       0.0.0.0/0            0.0.0.0/0            /* WireGuard 'server' */ MARK xset 0x1/0x7
Use command 'diag sql [ table_name ]' to see the SQL data (might be many lines!)
       Valid SQL Database tables: clients   fwmark    passthru  servers   traffic
devices   ipset     policy    session
             e.g. diag sql traffic will show the traffic stats SQL table
        WireGuard ACTIVE Peer Status: Clients 1, Servers 1
I think I am getting much close now because in the wgm status it does show my VPN IP and not my ISP but when I got to waht is myip.com on PC it still shows ISP IP.
I am still having issues with it not connecting and I am not sure what I am doing wrong.
Probably my shoddy script! :cool:
I don't want to upset anyone with my lack of knowledge I was just hoping to get it working.
We all started as noobs, and I assure you, despite my manky coding skills, the script does actually work....eventually!:D
I think it has more to do with me not knowing enough. I am getting closer and closer to having it work. I think. I just not sure if I am missing anything obvious. I posted my results from diag above is there anything else I can post to help get this working?
E:Option ==> diag
interface: wg21
  public key: FSRDl
peer: TB3Cv
interface: wg11
  public key: SM
peer: RR93
        WireGuard VPN Peers
    link/none
    link/none
        DEBUG:  RPDB rules
        DEBUG: Netstat
        DEBUG: UDP sockets.
        DEBUG:  -t filter
        DEBUG:  -t nat
        DEBUG:  -t mangle
Did you use the vpndirector clone command, as shown in post:
then you need to set 'client' Peer 'wg11' to Policy mode
e  = Exit Script [?]
E:Option ==> peer wg11 auto=p
    [✔] Updated 'wg11' AUTO=P
then restart the 'client' Peer 'wg11' in Policy mode
e  = Exit Script [?]
e.g.
E:Option ==> start wg11
    Requesting WireGuard VPN Peer start (wg11)
    wireguard-clientwg13: Initialising Wireguard VPN 'client' Peer (wg11) in Policy Mode to 96.44.189.98:51820 (# Mullvad USA, Dallas) DNS=193.138.218.74
    wireguard-clientwg13: Initialisation complete.
e  = Exit Script [?]
e  = Exit Script [?]
e.g.
Ok I did that and yes I ran uf dev and clone the VPN Director Settings.
<CODE>wireguard-clientwg11: Initialising Wireguard VPN 'client' Peer (wg11) in Policy Mode to 192..xxx.xxx.xxx:1443 (# TorGuard WireGuard Config) DNS=1.1.1.1
iptables: Chain already exists.</CODE>
OK,
So if
e  = Exit Script [?]
E:Option ==> vpndirector list
shows the cloned VPN Dircetor rules are in the SQL database, the diag doesn't show them as having been applied in the RPDB rule section,
Why, because you posted this?
which indicates 'client' Peer 'wg11' is NOT in Policy mode since you haven't followed the advice to issue the three commands in this post
It is indeed a bug :eek:,
i.e. if you stop a 'server' Peer that is configured to use passthru', then the Passthru( del ) function incorrectly overwrites the variable;
$VPN_ID="wg22" becomes $VPN_ID="wg11" :oops:
Consequently, if you have a custom 'wg22-down.sh' script then it wouldn't be executed - instead 'wg11-down.sh' would be executed (if it existed).
I have patched 'wg_server' on the 'dev branch, so you will need to update using
e  = Exit Script [?]
E:Option ==> uf dev
and once you have tested/confirmed the patch, I'll get it rolled out to the main branch ASAP.
Thanks for your fast reply. passthru is working as expected now.
OK,
So if
e  = Exit Script [?]
Sorry I did miss doing that but I have done it now.
If all else fails...
REBOOT
then hopefully in Syslog you will see both the 'server' Peer 'wg21' and the Torguard 'client' Peer 'wg11' auto started/initiialised.
diag should now also show lots of RPDB rules? and data transfers for 'client' Peer 'wg11'
Sorry for the confusion I ended up removing wgm last night after I couldn't get it working and since I figured that doing the VPN Director stuff would be beyond me. When I woke up today and saw you updated your script I decided to try again but I did forget to set the policy.
REBOOT
rebooted and still not working :(
REBOOT
interface: wg21
  public key: FSRDlT
peer: TB3Cv
interface: wg11
  public key: SMGjy
peer: RR93D1BA9XeVRV
  endpoint: 192.xxx.xxx.xxx:1443
        WireGuard VPN Peers
wg11    P     10.13.53.185/24  192.xxx.xxx.xxx:1443  1.1.1.1       # TorGuard WireGuard Config
31: wg21: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
    link/none
32: wg11: <POINTOPOINT,NOARP> mtu 1420 qdisc noop state DOWN group default qlen 1000
    link/none
        DEBUG:  RPDB rules
9910:   from 192.168.56.0/24 lookup main
9910:   from 192.168.50.0/24 lookup main
9910:   from 192.168.5.109 lookup main
9910:   from 192.168.5.103 lookup main
9910:   from 192.168.224.0/24 lookup main
9911:   from 192.168.55.0/24 lookup 121
9911:   from 192.168.5.0/24 lookup 121
9911:   from 192.168.24.0/24 lookup 121
        DEBUG: Netstat
        DEBUG: UDP sockets.
        DEBUG:  -t filter
Chain OUTPUT (policy ACCEPT 23977 packets, 6177K bytes)
        DEBUG:  -t nat
Chain PREROUTING (policy ACCEPT 3248 packets, 647K bytes)
1     7294  523K WGDNS1     udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:53 /* WireGuard 'client1 DNS' */
Chain POSTROUTING (policy ACCEPT 84 packets, 7469 bytes)
1     4004  279K DNAT       all  --  *      *       192.168.55.0/24      0.0.0.0/0            /* WireGuard 'client1 DNS' */ to:1.1.1.1
2       72  4837 DNAT       all  --  *      *       192.168.5.0/24       0.0.0.0/0            /* WireGuard 'client1 DNS' */ to:1.1.1.1
3     3148  234K DNAT       all  --  *      *       192.168.24.0/24      0.0.0.0/0            /* WireGuard 'client1 DNS' */ to:1.1.1.1
        DEBUG:  -t mangle
Chain FORWARD (policy ACCEPT 12334 packets, 1062K bytes)
Chain PREROUTING (policy ACCEPT 35811 packets, 5615K bytes)
interface: wg21
  public key: FSRDlT
peer: TB3Cv
interface: wg11
  public key: SMGjy
        WireGuard VPN Peers
    link/none
    link/none
        DEBUG:  RPDB rules
        DEBUG: Netstat
        DEBUG: UDP sockets.
        DEBUG:  -t filter
        DEBUG:  -t nat
        DEBUG:  -t mangle
Are you sure your wireguard internet client wg11 is actually working?
If you issue:
E:Option ==> show
Under wg11, do you see
latest handshake: 1 minute, 32 seconds ago
Or is that line missing, or timer over 3 minutes?
If ok, then these ips
192.168.5.0/24
192.168.24.0/24
Except for 5.103 and 5.109 are routed out via wg11.
So make sure you are you are using these ips when testing.
What is up with all these subnets? This is one of the most complex setups I've ever seen...
If you issue:
E:Option ==> show
192.168.5.0/24
192.168.24.0/24
Except for 5.103 and 5.109.
Hi I am testing and using 192.168.5.100 no I am not sure and if I had to guess I would say that it is not working.
here are the results from "show" I have not made a successful handshake just shows my torguard IP which it wasn't yesterday so I thought it was working for a minute.
E:Option ==> show
interface: wg11 192.xxx.xxx.xxx:1443 10.13.53.185/24 # TorGuard WireGuard Config
peer: R
interface: wg21 Port:51820 10.50.1.1/24 VPN Tunnel Network # RT-AX88U Server #1
peer: TB3 10.50.1.2/32 # Chewie_iPhone12Pro "Device"
If you issue:
E:Option ==> show
192.168.5.0/24
192.168.24.0/24
I just want to make sure I am understanding this because I could be way off. My intention is to have my router connect to my Torguard VPN and hide my IP for all systems on 192.168.5.0/24 except for 192.168.5.103 and 109.
That is how my OpenVPN was setup in GUI. I am not trying to have it so I can use my iPhone to connect to LAN. I have PiVPN setup for that and will use it until I can get WG working.
I just wanted to make sure I am able to do this and I am not mistaken with what I am trying to do.
This sounds very doable.
But you seem to have alot of rules you are not using? Where do these come from:
Are these subnets you are not using? If soo, could you remove them.
Anyhow, until you get your peer to handshake, there is no point in working with the rules but try to reduce complexity of your system. So it is understandable. Just make a single rule for your test computer and scrap all else. add more as it starts to work.
Try out your Torguard conf file on another system (I.e android wireguard) just to check that the conf file is good (some seem to die after some inactivity and you need to generate a new one).
I have 192.168.50.0/24 for my 5 GHz Guest wifi
I have 192.168.50.0/24 for my 5 GHz IoT devices wifi
I have 192.168.24.0/24 for my 2.4 GHz Guest wifi
I have 192.168.224.0/24 for my 2.4 GHz IoT devices wifi
I also had 192.168.56.0/24 setup for my Work Devices and set not to use VPN
Ok, but if none of these are going out vpn, then no rules would be needed for them. In Policy mode any ips not matching any rule will naturally be sent to wan. In my opinion you would only need these 3 rules:
Which would translate to wgm commands:
peer wg11 rule add wan 192.168.5.109 comment 109ToWan
peer wg11 rule add wan 192.168.5.103 comment 103ToWan
peer wg11 rule add vpn 192.168.5.0/24 comment Subnet2VPN
It would be even better to change the ips on .103 and .109 and devide your network to not have to make exception rules. This makes vpn dns work properly, more info here:
Still, 1st priority is just to get your handshakes going. Start with testing your .conf file.
