today I got RT-AC56U and will be experimenting tonight. I even bought a portable USB fan to cool the router off!
Merlin - could kindly point me in a direction - how to overclock the router?
can I do it using your firmware? what are the commands? thanks in advance!
So the plan is to flash the router with Merlin FW and measure speeds - naked, with VPN and default clocks, VPN with overclocking...
I won't offer any help in overclocking this router because I have no idea if the router will be able to recover in case you set the clock too high (in addition to not having any idea if it would be stable anyway). I don't want to take any responsibility for 150$ bricks, sorry
I'll drop you a hint however: you can manually overclock it the same way as the RT-N66U or RT-AC66U, which should be documented on the web if you try a Google search (or if someone else wants to tell you how).
I only tested it at 1000 MHz and for a few minutes.
