Simultaneous VPN Server and VPN Client
As far as I have understood, I need to set up a solution where the answer from the router won't go through the client VPN but to the WAN.
The problem is that I don't know how to do that in the asus router (web interface or IPTables).
As the OpenVPN Server (Source Port 1195) is hosted on the router, then exclude the router from the VPN in the Selective Routing GUI
Hi all,
I have the same issue as Thierry and I am glad that he found an answer.
If I understand the suggested method, it solves the issue and allows you to access your openVPN server from outside your home.
However I still have an issue regarding ISP privacy, as in your case your OpenVPN Server is not tunneled anymore through the 3rd party VPN provider, and the connection between your OpenVPN Server and your router (the exit point) is therefore not encrypted and can by see by your ISP.
Remote pc <--vpntunenel--> home VPN server <--wan--> ISP
It's still a good tradeoff because all your others devices are still tunnelled through your VPN client, but not your server.
Therefore, is there an additional method to avoid that ?
So far I only see eibgrad's #2 suggestion to have a 3rd party VPN provider that allows port forwarding. (https://forum.dd-wrt.com/phpBB2/viewtopic.php?p=1129398)
Other methods such as PBR technically work great but make the server exit connection directly go through the WAN and to the ISP.
Any thought ?
Any thought ?
Hi ,
On my personnal case, I just want to remotly acces to my house through VPN si it works fine with this solution. In case I'd like to use VPN when mobile, I use the VPN apps of my VPN provider.
By the way, having this solution working, I 'm able to have permanent VPN connected for my house, and there, I had few surprised in term of performance. Roughtly, the bandwith I have is divided per 3 when I activate the VPN on the router. The provider answered me that is link to the performance of the router itself, I have also stability issue (radio streaming is cut every 30s), so at the end, that solution is far to be good to me.
Any advice regarding a good VPN provider that works well on ASUS AC68U ?
thanks
Thierry
For me the problem is more strange!
I have client connecting to 443 port and server receiving at 1194
Both subnet ips are different .
The fact is that while both server and client on, I can connect remotely to my vpn server!
It does connect (using for example openvpn for Android), but it shows that I'm connected to my public IP (not VPN ip).
I need one of two things:
1 - able to remotely connect to my server (including connecting to lan devices, such as router or mas) via WAN.
2 - able to remotely connect to my server (including to lan devices, router and nas) through my AIRVPN client.
I tried many different configs and solutions and no sucess.
The strange fact is that I can indeed connect to my vpn server but don't have access to any website or lan decide.
Any thoughts? Thanks
Well I managed to get working the option 1, by adding the router IP to wan via policy routes.
And the 2 option? How can I be in my remote device, connecting to router via vpn served, and being connected to the airvpn that router is connected to?
Another question is - why is my download shown as upload on bandwidth monitor webpage?
Allow pass through according to this guide.
https://www.snbforums.com/threads/openvpn-server-and-client-question.38378/#post-316743
(You will find all information needed in this thread as well)
Do not forget make /jffs/scripts/firewall-start executable.
chmod a+rx /jffs/scripts/firewall-start
Then add subnet of VPN-server to go through OpenVPN Client via WebUI, for example 10.8.0.0/24 to go through VPN.
Then reboot your router and test.
Oh my God that's exactly what I need and was looking for! Thanks!!!
Isa that possible to put those commands on a sh file? Including the chmod...
So I can backup the commands and run them if for some reason I have to format the router - so I can't lost them and apply them just by running the script
