Skynet Skynet keeps failing to start
@jorgsmash
Here is my investigative work....
If your CDN whitelisting had properly loaded in from skynet, you would not have had to whitelist the teams IP address.
{ printf "AS714\nAS12222\nAS16625\nAS33438\nAS20446\nAS54113\nAS36459" | xargs -I {} sh -c 'curl -fsL --retry 3 --connect-timeout 3 --max-time 6 --retry-delay 1 --retry-all-errors https://asn.ipinfo.app/api/text/list/{} | awk -v asn={} '\''/^(((25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])\.){3}(25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])(\/(1?[0-9]|2?[0-9]|3?[0-2]))?)([[:space:]]|$)/{printf "add Skynet-Whitelist %s comment \"CDN-Whitelist: %s\"\n", $1, asn }'\'''
curl -fsL --retry 3 --connect-timeout 3 --max-time 6 --retry-delay 1 --retry-all-errors https://www.cloudflare.com/ips-v4 | awk '/^(((25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])\.){3}(25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])(\/(1?[0-9]|2?[0-9]|3?[0-2]))?)([[:space:]]|$)/{printf "add Skynet-Whitelist %s comment \"CDN-Whitelist: CloudFlare\"\n", $1 }'
curl -fsL --retry 3 --connect-timeout 3 --max-time 6 --retry-delay 1 --retry-all-errors https://ip-ranges.amazonaws.com/ip-ranges.json | awk 'BEGIN{RS="(((25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])\\.){3}(25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])(\\/(1?[0-9]|2?[0-9]|3?[0-2]))?)"}{if(RT)printf "add Skynet-Whitelist %s comment \"CDN-Whitelist: Amazon\"\n", RT }'
curl -fsL --retry 3 --connect-timeout 3 --max-time 6 --retry-delay 1 --retry-all-errors https://api.github.com/meta | awk 'BEGIN{RS="(((25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])\\.){3}(25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])(\\/(1?[0-9]|2?[0-9]|3?[0-2]))?)"}{if(RT)printf "add Skynet-Whitelist %s comment \"CDN-Whitelist: Github\"\n", RT }'
curl -fsL --retry 3 --connect-timeout 3 --max-time 6 --retry-delay 1 --retry-all-errors https://endpoints.office.com/endpoints/worldwide?clientrequestid="$(awk '{printf "%s", $1}' /proc/sys/kernel/random/uuid)" | awk 'BEGIN{RS="(((25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])\\.){3}(25[0-5]|(2[0-4]|1[0-9]|[1-9]|)[0-9])(\\/(1?[0-9]|2?[0-9]|3?[0-2]))?)"}{if(RT)printf "add Skynet-Whitelist %s comment \"CDN-Whitelist: Microsoft365\"\n", RT }'; wait; } 2>/dev/null | awk '!x[$0]++' | grep -E '.*[[:space:]]52.*CDN-Whitelist:.*Microsoft365.*'
add Skynet-Whitelist 52.96.0.0/14 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.100.0.0/14 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.238.78.88/32 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.112.0.0/14 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.122.0.0/15 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.238.119.141/32 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.244.160.207/32 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.104.0.0/14 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.108.0.0/14 comment "CDN-Whitelist: Microsoft365"
add Skynet-Whitelist 52.244.37.168/32 comment "CDN-Whitelist: Microsoft365"
would have covered the 52.113.194.132 IP.
I am using the version of skynet I have submitted a pull request for the CDN whitelisting issue.
Here is my ping test from a client on my network.
ping 52.113.194.132
PING 52.113.194.132 (52.113.194.132): 56 data bytes
64 bytes from 52.113.194.132: seq=0 ttl=118 time=22.885 ms
64 bytes from 52.113.194.132: seq=1 ttl=118 time=22.747 ms
64 bytes from 52.113.194.132: seq=2 ttl=118 time=23.672 ms
64 bytes from 52.113.194.132: seq=3 ttl=118 time=22.091 ms
64 bytes from 52.113.194.132: seq=4 ttl=118 time=19.494 ms
64 bytes from 52.113.194.132: seq=5 ttl=118 time=22.420 ms
64 bytes from 52.113.194.132: seq=6 ttl=118 time=23.725 ms
64 bytes from 52.113.194.132: seq=7 ttl=118 time=19.866 ms
64 bytes from 52.113.194.132: seq=8 ttl=118 time=22.166 ms
^C
--- 52.113.194.132 ping statistics ---
9 packets transmitted, 9 packets received, 0% packet loss
round-trip min/avg/max = 19.494/22.118/23.725 ms
And here are the entries present from my patched skynet.
RT-AX88U_Pro-29B8:/tmp/home/root# ipset list | grep -E '^52.*CDN-Whitelist:.*Microsoft365.*'
52.244.160.207 comment "CDN-Whitelist: Microsoft365"
52.238.119.141 comment "CDN-Whitelist: Microsoft365"
52.244.37.168 comment "CDN-Whitelist: Microsoft365"
52.238.78.88 comment "CDN-Whitelist: Microsoft365"
This is the pull request I have open
As you can tell, I discovered this issue three days ago by coincidence. I noticed the amount of CDN-Whitelisting entries would greatly vary in number between list processing done by skynet. It took a little investigative work, but it turns out that a couple of the curl commands would hang indefinitely producing no output, until the connection closed resulting in numerous missing CDN whitelist entries (the Microsoft365 list was the main culprit). This is when I made the connection to whitelist processing hangs reported to @thelonelycoder during diversion/skynet shared lists processing.
Sorry I missed this. I appreciate the investigative work. Quick question, does your outbound blocklist only block malware, or are there tracking/advertising IPs in there as well? I only ask because I see it's blocking a Netfilx-owned IP - 45.57.40.1. This is on my wife's iPhone, so I'm not sure if she was having any issues watching something, or if this IP is only tracking related and the streaming service doesn't rely on it. We watch netflix all the time without issue, so I assume blocking outbound connections to this IP isn't breaking the service.
Jun  9 13:17:29 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC= SRC=192.168.50.38 DST=45.57.40.1 LEN=64 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=TCP SPT=62229 DPT=443 SEQ=1539659743 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4010303060101080A0E6F38630000000004020000)
@jorgsmash
here is some info. This IP most likely found its way into a list due to being reported. For all we know, the IP could be one that is often hijacked or exploited. This is a common way attackers attempt to gain access by presenting themselves as a legitimate service.
The list maintainers I have downloaded have not gotten around to removing this entry off of their list. If it is not hindering your netflix service use, I'd advice against whitelisting it. However, if it does hinder your usage, then it is probably best to whitelist it.
@jorgsmash
All good, I can leave it blacklisted for now. Sorry if I asked this before, does the router pull updates for the lists on a regular basis? Every day, multiple times a day, etc.
Thank you!
Thank you!
It depends on how you configured it on first setup. You can change it if you like.
( firewall settings banmalware daily|weekly|disable ) Enable/Disable Automatic Malware List Updating
the options are daily, weekly, or disabled. Mine is set to daily.
heres how it appears for me using cru l in the terminal:
25 6 * * * sh /jffs/scripts/firewall banmalware #Skynet_banmalware#
Looks like mine is set to
25 17 * * * sh /jffs/scripts/firewall banmalware #Skynet_banmalware#
I've been asking for Asus routers with more than 1 or 2 GB of RAM for a decade.
Coming soon...
Did we ever get a router released with 2-4GB RAM? Lol
Not in Asus-land.
