Skynet Skynet - Router Firewall & Security Enhancements
# _____ _ _ __ #
# / ____| | | | / / #
# | (___ | | ___ _ _ __ ___| |_ __ __/ /_ #
# \___ \| |/ / | | | '_ \ / _ \ __| \ \ / / '_ \ #
# ____) | <| |_| | | | | __/ |_ \ V /| (_) | #
# |_____/|_|\_\\__, |_| |_|\___|\__| \_/ \___/ #
# __/ | #
# |___/ #
## - 13/09/2019 - Asus Firewall Addition By Adamm v6.8.6 #
## https://github.com/Adamm00/IPSet_ASUS #
Router Model; RT-AC86U
Skynet Version; (13/09/2019) (ee28cdb7c394bea16b2e215ed9f11d51)
iptables v1.4.15 - (eth0 @ 192.168.xx.x)
ipset v6.32, protocol version: 6
IP Address; (209.12.xx.xxxx)
FW Version; 384.13_0 (Jul 31 2019) (4.1.27)
df: /tmp/mnt/86U/skynet: can't find mount point
Install Dir; /tmp/mnt/86U/skynet ( / Space Available)
Syslog Location; () ()
Uptime; 0 days, 0 hours, 40 minutes.
Ram Available; (152M / 430M)
| Device Name | | | Local IP | | | MAC Address | | | Status |
Unknown | 192.168.xx.x | xx.xx.xx.xx.xx.xx| Inactive
* | 192.168.xx.xx | xx.xx.xx.xx.xx.xx | Inactive
DESKTOP-P228VON | 192.168.xx.xx| xx.xx.xx.xx.xx.xx| Online
Unknown | 192.168.xx.xx| xx.xx.xx.xx.xx.xx | Inactive
Unknown | 192.168.xx.xx | xx.xx.xx.xx.xx.xx | Online
Galaxy-Note9 | 192.168.xx.xx| xx.xx.xx.xx.xx.xx | Inactive
Unknown | 192.168.xx.xx | Unknown | Offline
Unknown | 209.12.xx.xx| xx.xx.xx.xx.xx.xx | DELAY
| Test Description | | | Result |
Internet-Connectivity | [Passed]
Write Permission | [Failed]
Firewall-Start Entry | [Passed]
Services-Stop Entry | [Passed]
SWAP | [Failed]
Cron Jobs | [Failed]
IPSet Comment Support | [Passed]
Log Level 5 Settings | [Passed]
Duplicate Rules In RAW | [Passed]
Inbound Filter Rules | [Failed]
Inbound Debug Rules | [Failed]
Outbound Filter Rules | [Failed]
Outbound Debug Rules | [Failed]
Whitelist IPSet | [Failed]
BlockedRanges IPSet | [Failed]
Blacklist IPSet | [Failed]
Skynet IPSet | [Failed]
| Setting | | | Status |
Autoupdate | [Disabled]
Auto-Banmalware Update | [Disabled]
Debug Mode | [Disabled]
Filter Traffic | [Selective]
Unban PrivateIP | [Disabled]
Log Invalid | [Disabled]
Ban AiProtect | [Disabled]
Secure Mode | [Disabled]
Fast Switch | [Disabled]
Syslog Location | [Custom]
IOT Blocking | [Disabled]
Country Lookup For Stats | [Disabled]
CDN Whitelisting | [Disabled]
6/17 Tests Sucessful
[#] IPs (+0) -- Ranges Banned (+0) || Inbound -- Outbound Connections Blocked! [debug] [0s]
Adamm attached a file from SkyNet
# _____ _ _ __ #
# __/ | #
# |___/ #
Router Model;
iptables v1.4.15 - (eth0 @ 192.168.51.1)
IP Address; (209.12.25.157)
Unknown | 192.168.51.6 | 5c:49:7d:e5:7c:da | Inactive
* | 192.168.51.17 | 00:9d:6b:da:c2:94 | Inactive
DESKTOP-P228VON | 192.168.51.40 | 00:11:22:33:44:55 | Online
Unknown | 192.168.51.102 | 00:1e:06:42:0d:1a | Inactive
Unknown | 192.168.51.113 | 30:59:b7:f4:3d:c5 | Online
Galaxy-Note9 | 192.168.51.151 | 44:91:60:81:db:cf | Inactive
Unknown | 192.168.51.170 | Unknown | Offline
Unknown | 209.12.25.129 | b0:fa:eb:c4:c1:00 | DELAY
SWAP | [Failed]
Your USB device isn’t mounted so Skynet can’t find its install directory.
Thank You for Your help Adamm, I am going to start over with everything. Can you say what I should do to remove everything now to be able to start from scratch.
welcome to the forum. Not sure what you mean by “everything “. But did you install Skynet through AMTM? If so, just go in to AMTM, open Skynet, uninstall it and then reinstall it.
if you haven’t used AMTM, then I suggest you install it - see https://www.snbforums.com/threads/amtm-the-snbforum-asuswrt-merlin-terminal-menu.42415/
and then uninstall Skynet through it and then reinstall. Certainly, AMTM is as much a must-have program as are Skynet and Diversion.
I like Skynet a lot! It take me a long time to understand the whole menu. The word List is used for different meanings in for example: Change Filter List, Exclude Individual Lists, Import IP List and List Entries. Below I have made a suggestion for the menu changes, what do you think? I suggest to use the word Blacklist instead of Banmalware because it can block much more than only malware.
  • [3] Blacklist (Banmalware)
    • Change Blacklist (Change Filter List)
    • Reset Blacklist (Reset Filter List)
    • Exclude Individual IP sets (Exclude Individual Lists)
      • Input Names Of IP sets To Exclude Seperated By Pipes (Input Names Of Lists To Exclude Seperated By Pipes)
    • Reset Excluded IP sets (Reset Exclusion List)
  • [4] Whitelist
    • View Entries (List Entries)
      • Select Entries To View (Select Entries To List)
  • [5] Import IP Set (Import IP List)
    • Import IP Set To List: (Select Where To Import List: )
  • [6] Exclude IP Set (Deport IP List)
  • [11] Settings
    • Skynet Autoupdate (Autoupdate)
    • Blacklist Autoupdate (Banmalware)
I've pushed v6.8.8 and adopted some of the suggestions above.
I did pass on the using the words IP Sets and overuse of the word Blacklist as it may lead to other confusion (people trying to import actual IP Sets, asking what ban vs blacklist means) etc.
Thanks for the fast update ;-)
I updated to v6.8.8 and the did a banmalware update (3,1). I got this:
[i] Downloading filter.list         | [0s]
[i] Refreshing Whitelists           | /opt/bin/skynet: line 5143: can't fork
[13s]
Edit:
After manually restarting skynet and update banmalware the problem disappeared...
[13s]
Edit:
Can't fork errors are firmware related and generally triggered by a misbehaving swap file. If it occurs again in future I'd start your investigation there.
I'm getting some errors in Skynet that I have never had before.
Here is the debug output as well.
#                                _____ _                     _             __                               #
#                                            __/ |                                                          #
#                                           |___/                                                           #
## - 06/10/2019 -                  Asus Firewall Addition By Adamm v6.8.8                                   #
Router Model; RT-AC3100
Skynet Version; v6.8.6 (06/10/2019) (99388957da691ea9867fc02de423107f)
iptables v1.4.15 - (eth0 @ 192.168.1.1)
IP Address; (xxx.xxx.xxx.xxx)
FW Version; 384.13_0 (Jul 31 2019) (2.6.36.4brcmarm)
Install Dir; /tmp/mnt/sda1/skynet (26.6G / 28.8G Space Available)
SWAP File; /tmp/mnt/sda1/myswap.swp (512.0M)
Banned Countries; cn br ir ua ar iq tw th lv ru ro cl sa pk bg
Uptime; 0 days, 0 hours, 6 minutes.
Ram Available; (290M / 503M)
Unknown                                  | 24.144.254.1     | 00:17:10:8d:38:12    | Online
Unknown                                  | 192.168.1.3      | 34:8f:27:1c:5a:00    | Inactive
Unknown                                  | 192.168.1.4      | 34:8f:27:1b:39:60    | Inactive
VEC0602RA                                | 192.168.1.11     | 44:85:00:da:be:a7    | Online
Philips-Hue                              | 192.168.1.33     | 00:17:88:a3:c7:a3    | Inactive
amazon-c6e6bfcf4                         | 192.168.1.65     | 08:a6:bc:37:88:e5    | DELAY
*                                        | 192.168.1.68     | 50:8c:b1:63:0b:0a    | Inactive
*                                        | 192.168.1.71     | 20:df:b9:b1:90:59    | Online
Unknown                                  | 192.168.1.85     | a4:da:22:2f:0d:a4    | Online
*                                        | 192.168.1.106    | f8:46:1c:31:fb:4b    | Online
*                                        | 192.168.1.141    | 84:a4:66:d2:82:64    | Inactive
iPhone                                   | 192.168.1.145    | e0:33:8e:c4:b0:bd    | Inactive
Brother-HL-L2340D                        | 192.168.1.146    | 28:56:5a:14:a1:7f    | Inactive
amazon-efc2ed738                         | 192.168.1.165    | 08:a6:bc:fd:4f:86    | Online
Google-Home-Mini                         | 192.168.1.213    | 20:df:b9:90:b2:c2    | Inactive
*                                        | 192.168.1.220    | fc:f1:36:12:9a:96    | Inactive
Unknown                                  | 192.168.1.225    | Unknown              | Offline
Unknown                                  | 192.168.1.230    | a0:c9:a0:eb:84:ea    | Online
Write Permission                    | [Passed]
SWAP                                | [Passed]
Inbound Logging Rules               | [Failed]
Outbound Logging Rules              | [Failed]
Skynet Auto-Updates                 | [Enabled]
Malware List Auto-Updates           | [Enabled]
Logging                             | [Disabled]
Filter Traffic                      | [Enabled]
Unban PrivateIP                     | [Enabled]
Ban AiProtect                       | [Enabled]
Secure Mode                         | [Enabled]
Syslog Location                     | [Default]
Country Lookup For Stats            | [Enabled]
CDN Whitelisting                    | [Enabled]
8/17 Tests Sucessful
[1-15]: 11
Select Setting To Toggle:
[1]  --> Skynet Auto-Updates   | [Disabled]
[2]  --> Malware List Auto-Updates | [daily]
[3]  --> Logging               | [Enabled]
[4]  --> Filter Traffic        | [all]
[5]  --> Unban PrivateIP       | [Enabled]
[6]  --> Log Invalid Packets   | [Disabled]
[7]  --> Ban AiProtect         | [Disabled]
[8]  --> Secure Mode           | [Enabled]
[9]  --> Fast Switch           | [Disabled]
[10] --> Syslog Location       | [Default]
[11] --> IOT Blocking          | [Disabled]
[12] --> Stats Country Lookup  | [Enabled]
[13] --> CDN Whitelisting      | [Enabled]
The settings layout can be fixed with something like:
-- printf "%-30s | %-40s\\n" "[1] --> Skynet Skynet Auto-Updates"
++ printf "%-35s | %-40s\\n" "[1] --> Skynet Skynet Auto-Updates"
etc...
You were right, it occured again. How do I investigate the swap file problem?
Edit:
And where can I see my current custom filter list url?
Edit2:
Indeed, my USB drive had some errors, I managed to fix it. Skynet banmalware update is working again.
#                                _____ _                     _             __                               #
#                                            __/ |                                                          #
#                                           |___/                                                           #
SWAP                                | [Passed]
On a clean reboot do you see any Skynet related errors in the syslog? Better yet try re-run the install command (you wont lose any data) and see if that corrects the issue.
Good to hear
etc...
Thanks, forgot all about adjusting the column width
Weird; I had the same problem today on (also) an AC86U...
A coincidence I guess, the fork issue has been around since the launch of the AC86U and IIRC can only be fixed by Broadcom in the SDK.
I had the USB not mounted issue (not the fork issue), but indeed still a coincidence I guess, unless more 86U owners report this.
Good to hear
Reinstall seems to have gotten rid of the errors. I will monitor and see what happens.
Thanks.
I just started getting these spam messages in my log: kernel: DROP IN=eth0 after I manually tried updating Skynet. I'm using an 86U. I reformatted the USB drive and reinstalled and skynet failed to launch. Had 3 red fail signs. A restart didn't work either.
Please post the exact output from Skynet in the syslog when it fails to start along with the output of the following command;
sh /jffs/scripts/firewall debug info
Several re-installs did the trick. No biggie,
Thanks!
Today I saw there was a new update for Skynet, when tried through AMTM to get in to update it, this error showed up:
Oct  9 08:00:01 kernel: EXT4-fs error (device sda1): add_dirent_to_buf:1280: inode #262145: block 1056800: comm sh: bad entry in directory: inode out of bounds - offset=0(0), inode=1074004099, rec_len=12, name_len=1
What can I do to fix it?
