Skynet Skynet - Router Firewall & Security Enhancements
Went back to v6.9.2 can`t get rid of "Consolidating Blacklist | curl: option -fsLZ: is unknown" anymore and turned off auto update
Worked before when i added "export PATH=/tmp/mnt/Zastoff/entware/bin:/sbin:/bin:/usr/sbin:/usr/bin:$PATH" to the script, That`s not working either now
Downloading filter.list | [1s]
Refreshing Whitelists | [10s]
curl: try 'curl --help' for more information
[7s]
Filtering IPv4 Addresses | [6s]
Filtering IPv4 Ranges | [0s]
Applying New Blacklist | [11s]
Refreshing AiProtect Bans | [1s]
Saving Changes | [5s]
For Whitelisting Assistance -
https://www.snbforums.com/threads/r...wall-security-enhancements.16798/#post-115872
[#] 143177 IPs (+0) -- 1627 Ranges Banned (+0) || 8 Inbound -- 0 Outbound Connections Blocked! [banmalware] [44s]
[7s]
Do you have 7.0.2 version now? Several fixes pushed in the last couple hours.
Have not tested the 7.0.2 did the roll back just before that release
I'm still getting this with 7.0.2.
Downloading filter.list | [0s]
Refreshing Whitelists | [3s]
[0s]
[*] List Content Error Detected - Stopping Banmalware
Whats the output of;
/opt/bin/curl --version
(I assume you are using entware if you chose not to update your firmware version to alternatively correct the issue)
Gave 7.02 a try same thing "Consolidating Blacklist | curl: option -fsLZ: is unknown"
RT-AC87U-99F8:/tmp/home/root# /usr/sbin/curl --version
curl 7.65.3 (arm-unknown-linux-gnu) libcurl/7.65.3 OpenSSL/1.0.2t zlib/1.2.5
Release-Date: 2019-07-19
Protocols: file ftp ftps http https imap imaps pop3 pop3s rtsp smb smbs smtp smtps tftp
Features: HTTPS-proxy IPv6 Largefile libz NTLM NTLM_WB SSL TLS-SRP UnixSockets
RT-AC87U-99F8:/tmp/home/root# /opt/bin/curl --version
curl 7.66.0 (arm-openwrt-linux-gnu) libcurl/7.66.0 OpenSSL/1.1.1d zlib/1.2.11
Release-Date: 2019-09-11
Protocols: file ftp ftps http https imap imaps pop3 pop3s rtsp smtp smtps tftp
Features: HTTPS-proxy IPv6 Largefile libz SSL
I'm not totally against updating to .14, I just had some stability issues with it.
curl 7.65.3 (arm-buildroot-linux-gnueabi) libcurl/7.65.3 OpenSSL/1.0.2s
Features: HTTPS-proxy IPv6 Largefile NTLM NTLM_WB SSL TLS-SRP UnixSockets
Just realized I pasted the wrong version check, but the last thing I can think of is your entware curl version hasn't been updated;
opkg update
opkg upgrade curl
Try the same steps posted above, if that doesn't work the only option I see left is your $PATH binary isn't the default entware one.
Assuming it still doesn't work whats the output of;
echo $PATH
curl 7.66.0 (aarch64-openwrt-linux-gnu) libcurl/7.66.0 OpenSSL/1.1.1d zlib/1.2.11
Refreshing Whitelists | [2s]
[0s]
[0s]
echo $PATH
echo $PATH
/opt/bin:/opt/sbin:/bin:/usr/bin:/sbin:/usr/sbin:/home/drizzt:/mmc/sbin:/mmc/bin:/mmc/usr/sbin:/mmc/usr/bin:/opt/sbin:/opt/bin:/opt/usr/sbin:/opt/usr/bin
I'm going to have to sleep on this one and approach it on a clear head , makes no logical sense to me why its failing to use the entware binaries from all the information you both provided.
Thanks for the information, sorry I couldn't provide a solution just yet beyond downgrade and wait for a firmware update to natively correct the issue. o_O
could you not detect if curl is present in entware and call it like i do for sqlite?
[ -f /opt/bin/sqlite3 ] && SQLITE3_PATH=/opt/bin/sqlite3 || SQLITE3_PATH=/usr/sbin/sqlite3
