Skynet Skynet - Router Firewall & Security Enhancements
I did this but no luck. Would you be willing share your font type and size settings? I am still on UTF-8. Not sure why I can't get this to work right.
Thank you!
It worked as soon as I updated to the v7.0.2. Thank you @ Adamm!
I'm going to have to sleep on this one and approach it on a clear head , makes no logical sense to me why its failing to use the entware binaries from all the information you both provided.
Thanks for the information, sorry I couldn't provide a solution just yet beyond downgrade and wait for a firmware update to natively correct the issue. o_O
Can it be that because you aren’t exporting any PATH at all in his scenario that the eval command doesn’t get a proper PATH to inherit?
7.0.2 working on my 87U.
[i] Downloading filter.list         | [1s]
[i] Refreshing Whitelists           | [7s]
[i] Consolidating Blacklist         | [9s]
[i] Filtering IPv4 Addresses        | [5s]
[i] Filtering IPv4 Ranges           | [0s]
[i] Applying New Blacklist          | [14s]
[i] Refreshing AiProtect Bans       | [0s]
[i] Saving Changes                  | [8s]
grifo@r1:/tmp/home/root# echo $PATH
/opt/bin:/opt/sbin:/bin:/usr/bin:/sbin:/usr/sbin:/home/grifo:/mmc/sbin:/mmc/bin
grifo@r1:/tmp/home/root# curl --version
curl 7.66.0 (arm-openwrt-linux-gnu) libcurl/7.66.0 OpenSSL/1.1.1d zlib/1.2.11
Release-Date: 2019-09-11
Protocols: file ftp ftps http https imap imaps pop3 pop3s rtsp smtp smtps tftp
Features: HTTPS-proxy IPv6 Largefile libz SSL
Last idea is that /opt/bin/curl is not executable. That would skip it in the path.
@Zastoff please check if it is.
ls -l /opt/bin/curl
Edit: No, this is a dead end.
With:
if [ "$(/usr/sbin/curl --version | awk 'NR >= 1 && NR <= 1 {print $2}' | tr -d '.')" -lt "7660" ]; then
    if [ -f "/opt/bin/opkg" ] && [ ! -f "/opt/bin/curl" ]; then
        opkg update
        opkg install curl
    elif [ "$(/opt/bin/curl --version | awk 'NR >= 1 && NR <= 1 {print $2}' | tr -d '.')" -lt "7660" ]; then
        opkg update
        opkg upgrade curl
    elif [ ! -f "/opt/bin/opkg" ]; then
        logger -st Skynet "[!] curl Version Outdated - Please Update Firmware Or Install Entware"
    fi
else
    export PATH=/sbin:/bin:/usr/sbin:/usr/bin:$PATH
fi
Why is $PATH being re-written in the last else -- fi? Won't that give precedence to the /sbin version of curl if the script is run a *second* time, un-doing the opkg install of curl to /opt/bin?
With:
        opkg update
        opkg install curl
        opkg update
        opkg upgrade curl
    fi
else
fi
It checks the version of the read-only curl in firmware. If it’s new enough, it prioritizes the firmware version. Otherwise it leaves the PATH untouched assuming Entware version will be first in the path. The /usr/sbin/curl version won’t change without a firmware upgrade.
If entware is installed it should default to the path set in /opt/etc/profile which gives entware binaries precedence
In the first if statement we specifically check the /usr/sbin/curl binary so old firmware versions will always fail this test.
Good to know the fix is working atleast for some people o_O
Yes, but once the script has installed the new curl in /opt/bin on the first pass (when everything will work), the *NEXT TIME* the script is run, it will go to the else statement, which rewrites $PATH to put sbin upfront.
The opkg installation changes $PATH so /opt/bin is at the front, as shown in /opt/etc/profile. The statement on the last else -- fi undoes this, if the script is run again.
Why is the $PATH statement even there?
J
Where can I find my Custom Filter List URL?
I believe its shown when running a malware list update or you can manually find it inside the config file in Skynets install dir.
Thats why we specifically check "/usr/sbin/curl --version" rather then plain old "curl --version" which as you stated would prioritize entware on the second run.
We added the path var around two years ago because I vaguely remember a specific stripped down busybox binary acting differently then the full entware version (git history shows it may have been the find binary), it also makes development easier so I don't accidentally use non supported flags. Not something I want to remove without further investigation as it may cause other issues.
Still very confusing why the fix is working for some but not others o_O
Check the version, and act accordingly:
admin@stargateax88:/tmp/home/root# curl -V | head -n 1 | cut -f 2 -d " "
7.66.0
7.66.0
Already doing that;
        opkg update
        opkg install curl
        opkg update
        opkg upgrade curl
    fi
else
fi
This seems to work for everyone except @Zastoff and (prior to upgrading)@Andy1932 . For those two regardless of what we tried the built-in curl binary was always being prioritized regardless of their path vars. Very confusing.
Could other running scripts be interfering with this? Looking at Zastoff's sig he has 2 scripts I don't have, DNSCrypt-proxy and scMerlin.
Barring any PATH statements in /jffs/configs/profile.add.
Always hard troubleshooting someone else’s router. ;)
I still don’t like something about why it would work for @Zastoff when he would put the absolute path to Entware (/tmp/mnt/.../bin). I must learn to let go.
Tested again with 7.0.2 and still got the "Consolidating Blacklist | curl: option -fsLZ: is unknown" on Malware Blacklist update
Tested again with adding my export PATH=.. but after all the entware checking
opkg update
opkg install curl
opkg update
opkg upgrade curl
fi
else
fi
export PATH=/tmp/mnt/Zastoff/entware/bin:/sbin:/bin:/usr/sbin:/usr/bin:$PATH
printf '\033[?7l'
And now Malware Blacklist update works!! And i read your posts and started thinking.. i use a older netflix script did a check in IPSET_Netflix.sh and there is some entware checking in that script, Can that be my problem?
Added echo $PATH to script
Checked with my export PATH
and get:
/tmp/mnt/Zastoff/entware/bin:/sbin:/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/sbin:/usr/bin:/bin:/usr/bin:/sbin:/usr/sbin:/home/drizzt:/mmc/sbin:/mmc/bin:/mmc/usr/sbin:/mmc/usr/bin:/opt/sbin:/opt/bin:/opt/usr/sbin:/opt/usr/bin
Removed my export PATH
and get:
So it would appear that the initial version check is indeed failing for some reason, and the subsequent export path statement is pushing the /usr/sbin version over /opt/bin.
Could you see if adding an export path with /opt/bin first instead of your /tmp/mnt/Zastoff.. works?
export PATH=/opt/bin:/sbin:/bin:/usr/sbin:/usr/bin:$PATH Works!
echo $PATH:
/opt/bin:/sbin:/bin:/usr/sbin:/usr/bin:/opt/bin:/sbin:/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/sbin:/usr/bin:/bin:/usr/bin:/sbin:/usr/sbin:/home/drizzt:/mmc/sbin:/mmc/bin:/mmc/usr/sbin:/mmc/usr/bin:/opt/sbin:/opt/bin:/opt/usr/sbin:/opt/usr/bin
opkg update
opkg install curl
opkg update
opkg upgrade curl
fi
else
fi
printf '\033[?7l'
I've had the same issue as Zastoff with 7.0.2 on an RT-AC3200 and merlin firmware 384_13_2. Got it working for now using the same fix above.
