hmm the question is how does it interferee with gaming i mean my goal is to get the lowest latency and response from my internet i dont care really about security but i mean if some adds/things attack my internet and i dont see it, it would decrease my performance?
ok thanks i will give it a tryany configs with different scripts that i need to consider to enable disable ?
I notice a definite impact on latency with skynet enabled, its not too severe and may be worth the extra security protectionsSkynet has no measurable performance impact on your connection. Technically its faster as we block connections in the raw table which is the earliest possible point and avoids conntracking, but again this is quite hard to measure. Our main goal is enhanced network security.
I don’t see the IP for waterfox.net (51.159.31.11) blocked by the default Skynet lists. What do you see for a block reason when you run:Waterfox.net is whitelisted by skynet (manually), why does does your firewall continue blocking whitelisted domains every day or two?
firewall stats search ip 51.159.31.11
Hi, I have been using Skynet for 3 or 4 weeks now and recently I have noticed 2 issues and am look to find out if it Skynet or not.
1. Updates from Google store have been very slow, almost a crawl.
2. Today I am in the middle of downloading a major update from AT&T for the note 9 and it too is exhibiting the same very slow download. The file size is 1012.22mb and after over 2 hours it's only downloaded 36.6mb, 3%.
My note is on my local wifi network and in the past it would take maybe 20-30 minutes to download such a update.
I do realize it may be AT&T but both issues seem very odd to me, since I not seen this behavior until now.
So I am asking is there a connection to Skynet? How can I check it?
Ok, thanks for that. I am now downloading slow but at least it's much faster up to 8% in a couple minutes. So it does seem to interfere with AT&T updates.You can Temporarily disable Skynet and check again while it disabled (9->1 in the menu)
My Google play and Xiaomi updates are normal .I dont have a problem with download speed.Hi, I have been using Skynet for 3 or 4 weeks now and recently I have noticed 2 issues and am look to find out if it Skynet or not.
Welcome To SNBForums
