dave14305
Part of the Furniture
If science would put as much effort into a vaccine as you put into your latency, this pandemic would have been over weeks ago.so you guys think skynet dont helps with gaming ;D ^^ any futher tips for low latency
If science would put as much effort into a vaccine as you put into your latency, this pandemic would have been over weeks ago.![]()
Hi, I have been using Skynet for 3 or 4 weeks now and recently I have noticed 2 issues and am look to find out if it Skynet or not.
1. Updates from Google store have been very slow, almost a crawl.
2. Today I am in the middle of downloading a major update from AT&T for the note 9 and it too is exhibiting the same very slow download. The file size is 1012.22mb and after over 2 hours it's only downloaded 36.6mb, 3%.
My note is on my local wifi network and in the past it would take maybe 20-30 minutes to download such a update.
I do realize it may be AT&T but both issues seem very odd to me, since I not seen this behavior until now.
So I am asking is there a connection to Skynet? How can I check it?
OK. Does not seem to be Skynet as I rebooted the router, RT-AC5300 and the update finished in a about 2 minutes.
All seems well now.
What i can feel is that my hit registration ingame got worse when i use skynet
Jul 28 16:55:05 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=45.145.66.33 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=11479 PROTO=TCP SPT=58431 DPT=37201 SEQ=29573227 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jul 28 16:55:13 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=45.145.66.33 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=62577 PROTO=TCP SPT=58431 DPT=37511 SEQ=764517147 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jul 28 16:55:17 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=94.102.49.191 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=27258 PROTO=TCP SPT=58859 DPT=3496 SEQ=792828479 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jul 28 16:55:31 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=45.145.66.33 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=62679 PROTO=TCP SPT=58431 DPT=39571 SEQ=1257870249 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Jul 28 16:55:32 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=183.136.225.45 DST=XX.XXX.XXX.XXX LEN=44 TOS=0x08 PREC=0x20 TTL=108 ID=42540 PROTO=TCP SPT=13688 DPT=1935 SEQ=1960750360 ACK=0 WINDOW=29200 RES=0x00 SYN URGP=0 OPT (020405B4)
Jul 28 16:55:33 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=211.65.196.105 DST=XX.XXX.XXX.XXX LEN=48 TOS=0x08 PREC=0x20 TTL=98 ID=18813 PROTO=TCP SPT=50581 DPT=22 SEQ=716793717 ACK=1629916811 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B401010402)
Jul 28 16:55:49 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=192.35.169.38 DST=XX.XXX.XXX.XXX LEN=44 TOS=0x08 PREC=0x40 TTL=31 ID=23350 PROTO=TCP SPT=48333 DPT=8883 SEQ=3523205794 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4)
Jul 28 16:55:54 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=202.154.180.51 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=12690 PROTO=TCP SPT=54029 DPT=12929 SEQ=479723262 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Hello! I have had skynet for a few days and my logs is flooded with the following entries.
Code:Jul 28 16:55:05 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=45.145.66.33 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=11479 PROTO=TCP SPT=58431 DPT=37201 SEQ=29573227 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 Jul 28 16:55:13 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=45.145.66.33 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=62577 PROTO=TCP SPT=58431 DPT=37511 SEQ=764517147 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 Jul 28 16:55:17 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=94.102.49.191 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=27258 PROTO=TCP SPT=58859 DPT=3496 SEQ=792828479 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 Jul 28 16:55:31 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=45.145.66.33 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=62679 PROTO=TCP SPT=58431 DPT=39571 SEQ=1257870249 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 Jul 28 16:55:32 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=183.136.225.45 DST=XX.XXX.XXX.XXX LEN=44 TOS=0x08 PREC=0x20 TTL=108 ID=42540 PROTO=TCP SPT=13688 DPT=1935 SEQ=1960750360 ACK=0 WINDOW=29200 RES=0x00 SYN URGP=0 OPT (020405B4) Jul 28 16:55:33 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=211.65.196.105 DST=XX.XXX.XXX.XXX LEN=48 TOS=0x08 PREC=0x20 TTL=98 ID=18813 PROTO=TCP SPT=50581 DPT=22 SEQ=716793717 ACK=1629916811 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B401010402) Jul 28 16:55:49 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=192.35.169.38 DST=XX.XXX.XXX.XXX LEN=44 TOS=0x08 PREC=0x40 TTL=31 ID=23350 PROTO=TCP SPT=48333 DPT=8883 SEQ=3523205794 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4) Jul 28 16:55:54 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=88:d7:f6:6b:ee:a8:40:d8:55:06:9b:43:08:00 SRC=202.154.180.51 DST=XX.XXX.XXX.XXX LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=12690 PROTO=TCP SPT=54029 DPT=12929 SEQ=479723262 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Is there a way to reduce them, because there is no way to track any problems in the huge log
That's normal and can't be reduced AFAIK. Those log entries are kinda the whole point of Skynet.
Just be careful tho, those might cause high ping times.You may want to install scribe and uiScribe. It will at least separate the Skynet logs out of the normal syslog entries.
/S just in case this is needed here.
the /S was a trigger for sarcasm.These programs cause no issues on my setup. Not sure how they would affect network latency.
New AC86U user -- how would Skynet relate to AiProtection/Trend Micro feature? Would I want that enabled if I used Skynet?
Welcome To SNBForums
