Skynet Skynet - Router Firewall & Security Enhancements
Updated to 7.2.2 today but now Skynet isn't working anymore :(
I restarted skynet, updated skynet but nothing helps.
Any hint how to solve this issue?
I have successfully updated to 7.2.2.
but it is still showing no data to display eventhou putty stats are showing data.
is there anything else that I was suppose to update?
I pushed another hotfix. It appears you were rate limited by db-ip (where we get country info from), so the country field in your stats was empty causing the "no data to display" error incorrectly.
Now in the event data is missing we now replace it with a *
What is the output of;
firewall debug info
Along with any related skynet output from the syslog
debug output:
| Test Description | | | Result |
Internet-Connectivity | [Passed]
Write Permission | [Passed]
Config File | [Passed]
Firewall-Start Entry | [Passed]
Services-Stop Entry | [Passed]
Service-Event Entry | [Passed]
Profile.add Entry | [Passed]
SWAP File | [Passed]
Cron Jobs | [Failed]
NTP Sync | [Passed]
IPSet Comment Support | [Passed]
Log Level 5 Settings | [Passed]
Duplicate Rules In RAW | [Passed]
IPSets | [Failed]
IPTables Rules | [Failed]
Local WebUI Files | [Passed]
Mounted WebUI Files | [Failed]
MenuTree.js Entry | [Failed]
| Setting | | | Status |
Skynet Auto-Updates | [Enabled]
Malware List Auto-Updates | [Enabled]
Logging | [Enabled]
Filter Traffic | [Enabled]
Unban PrivateIP | [Enabled]
Log Invalid Packets | [Disabled]
Import AiProtect Data | [Enabled]
Secure Mode | [Enabled]
Fast Switch List | [Disabled]
Syslog Location | [Custom]
IOT Blocking | [Disabled]
Country Lookup For Stats | [Enabled]
CDN Whitelisting | [Enabled]
Display WebUI | [Enabled]
13/18 Tests Sucessful
[*] Rule Integrity Violation - [ #1 #2 #3 #4 #5 #6 #7 #8 #16 #17 #18 ]
[*] Mounted File Missing - [ chart.js chartjs-plugin-zoom.js hammerjs.js skynet.asp stats.js ]
I checked the ssd / the skynet folder, where I found the "missing files" in the webui folder.
debug output:
There should be some syslog output indicating why Skynet failed to start. Use the following command and check for any output a few minutes later;
firewall restart
Thank you very much!
I restarted the router and now an additional Skynet (7.2.2. again) update was available.
Update done and Skynet started without errors. I assume the first 7.2.2. update was not successfully today.
I'm getting an error message: "[*] IPSet Version Not Supported - Please Update To Latest Firmware"
Installed it using amtm. My router is an ASUS RT-AC66U (not b1) running Firmware 374.43_44EAj9527 (Merlin LTS fork).
Is there a way to make Skynet work on this firmware version? Maybe using an old version of it?
Thanks in advance.
Thanks in advance.
Unfortunately the kernel version is too old on MIPS routers and doesn't support nessesary IPSet features. There's no way around it.
got a new modem which does not support bridge mode, im getting the following message:
Skynet: [*] Private WAN IP Detected 192.168.0.x - Please Put Your Modem In Bridge Mode / Disable CG-NAT
should i be worried? if i check my ip, i get the wan ip... is it a Security issue, what should i change?
hello @Adamm
lately i have been having issues with some regular websites (ipinfo.io - plotly.com) being blocked by skynet. Im currently running latest version.
both websites are hosted on ip address 216.239.38.21 (sometimes it switches to 216.239.34.21) which is being blocked by skynet. 216.239.38.21 and 216.239.34.21 are under AS15169 Google LLC which i would think its safe?
is there anything wrong on my setup of do i need to start manually un-banning these ip addresses?
tracetcp plotly.com:443 -t 300
Tracing route to 216.239.38.21 [any-in-2615.1e100.net] on port 443
Over a maximum of 30 hops.
1       *       *       *       Request timed out.
2       *       *       *       Request timed out.
3       *       *       *       Request timed out.
tracetcp ipinfo.io:443 -t 300
[$] /jffs/scripts/firewall stats search ip 216.239.38.21 10
[i] Logging Data Detected in /tmp/mnt/sda1/skynet/skynet.log - 9.8M
[i] Monitoring From Sep 7 18:01:47 To Sep 11 17:24:58
[i] 34547 Block Events Detected
[i] 4149 Unique IPs
[i] 9 Manual Bans Issued
216.239.38.21 is NOT in set Skynet-Whitelist.
216.239.38.21 is in set Skynet-Blacklist.
216.239.38.21 is NOT in set Skynet-BlockedRanges.
Blacklist Reason;
"BanAiProtect: aquawaterpurifiers.com"
Associated Domain(s);
gpstools.app
plotly.com
ipinfo.io
ssl-api.itranslateapp.com
api.getbouncer.com
[i] IP Location - Canada (GOOGLE / AS15169)
[i] 216.239.38.21 First Tracked On Sep 11 09:37:42
[i] 216.239.38.21 Last Tracked On Sep 11 17:21:54
[i] 172 Blocks Total
Event Log Entries From 216.239.38.21;
First Block Tracked From 216.239.38.21;
Sep 11 09:37:42 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=128 ID=16662 DF PROTO=TCP SPT=
10 Most Recent Blocks From 216.239.38.21;
Sep 11 17:10:31 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=1 ID=15848 DF PROTO=TCP SPT=35
Sep 11 17:10:31 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=2 ID=15848 DF PROTO=TCP SPT=34
Sep 11 17:10:32 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=2 ID=15848 DF PROTO=TCP SPT=15
Sep 11 17:10:32 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=2 ID=15848 DF PROTO=TCP SPT=24
Sep 11 17:10:33 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=3 ID=15848 DF PROTO=TCP SPT=37
Sep 11 17:10:33 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=3 ID=15848 DF PROTO=TCP SPT=22
Sep 11 17:10:34 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=3 ID=15848 DF PROTO=TCP SPT=15
Sep 11 17:10:34 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=4 ID=15848 DF PROTO=TCP SPT=40
Sep 11 17:10:35 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=4 ID=15848 DF PROTO=TCP SPT=16
Sep 11 17:21:54 RT-AC3100-0548 kernel: [BLOCKED - OUTBOUND] IN=br0 OUT= MAC=4c:ed:fb:ac:05:48:7c:b2:7d:d0:32:8e:08:00 SRC=10.0.0.41 DST=216.239.38.21 LEN=52 TOS=0x00 PREC=0x00 TTL=128 ID=17591 DF PROTO=TCP SPT=
you are under NAT so skynet wont help you much on the incoming connections since they are being filtered at modem level.
try to get a public wan ip from your ISP on your router via either Bridge mode (you said you dont have that feature) or any MAC passthrough option on the modem.
firewall debug info
Cron Jobs | [Passed]
NTP Sync | [Passed]
IPSets | [Passed]
IPTables Rules | [Passed]
Mounted WebUI Files | [Passed]
MenuTree.js Entry | [Passed]
Logging | [Enabled]
Syslog Location | [Default]
18/18 Tests Sucessful
[#] 311549 IPs (+0) -- 2058 Ranges Banned (+0) || 7 Inbound -- 0 Outbound Connections Blocked! [debug] [11s]
the stats are displaying.
| IP Address | | | AlienVault | | | Ban Reason | | | Associated Domains |
42.194.154.20 () | https://otx.alienvault.com/indicator/ip/42.194.154.20 | * | stat.tpns.tencent.com
104.250.52.209 () | https://otx.alienvault.com/indicator/ip/104.250.52.209 | BanMalware: alienvault_reputation.ipset | shuc-other.ksord.com
114.40.138.107 () | https://otx.alienvault.com/indicator/ip/114.40.138.107 | BanMalware: alienvault_reputation.ipset |
42.194.172.19 () | https://otx.alienvault.com/indicator/ip/42.194.172.19 | * |
Top 10 HTTP(s) Blocks (Outbound);
| Hits | | | IP Address | | | AlienVault | | | Ban Reason | | | Associated Domain
32x | 42.194.154.20 () | https://otx.alienvault.com/indicator/ip/42.194.154.20 | * | stat.tpns.tencent.c
20x | 104.250.52.209 () | https://otx.alienvault.com/indicator/ip/104.250.52.209 | BanMalware: alienvault_reputation.ipset | shuc-other.ksord.co
15x | 42.194.172.19 () | https://otx.alienvault.com/indicator/ip/42.194.172.19 | * |
1x | 114.40.138.107 () | https://otx.alienvault.com/indicator/ip/114.40.138.107 | BanMalware: alienvault_reputation.ipset |
Top 10 Blocks (Inbound);
2878x | 80.82.77.237 () | https://otx.alienvault.com/indicator/ip/80.82.77.237 | BanMalware: alienvault_reputation.ipset |
1407x | 80.82.77.231 () | https://otx.alienvault.com/indicator/ip/80.82.77.231 | BanMalware: alienvault_reputation.ipset |
921x | 89.248.168.222 () | https://otx.alienvault.com/indicator/ip/89.248.168.222 | BanMalware: firehol_level3.netset* |
697x | 45.145.67.249 () | https://otx.alienvault.com/indicator/ip/45.145.67.249 | BanMalware: firehol_level2.netset* |
but in the GUI it is still staying no data to display
firewall debug info
NTP Sync | [Passed]
IPSets | [Passed]
Logging | [Enabled]
Assuming you are running the latest version, please post a screenshot of the discrepancy along with an updated copy of skynet.log and stats.js
hello @Adamm
[i] 4149 Unique IPs
Blacklist Reason;
gpstools.app
plotly.com
ipinfo.io
api.getbouncer.com
AiProtect flagged a website you visited as malicious (aquawaterpurifiers.com), Skynet then used this flag to ban the corresponding IP. If this is causing false positives due to other sites on the same server, you can whitelist the IP with the following guide;
alright so im "secure" in that way. Port-Triggering & Port-Forwarding is possible nothing more... sadly
If I decide to use Skynet, do I need to disable anything on router before/after I've installed Skynet ?
Currently got AIProtection switched on.
Skynet works seamlessly with the router, no need to disable anything for it to work properly. And it interacts with AIProtection, forming a more perfect union.
@Adamm HI,
I ran into a problem when disconnecting the USB drive from the second port of the router. When disconnecting from webui, the swap file is unmounted. The problem is in the script /jffs/scripts/unmount
swapoff -a 2>/dev/null # Skynet
To solve this problem, can use a variable from Merlin's instructions for unmount
swapoff $1/myswap.swp 2>/dev/null # Skynet
