I was waiting for a new firmware. So many users are having lots of issues with a brand new 45149. Wait again?
OMG... What's your problem ASUS?
For example, AiMesh.I'm not having any problem with the latest release. What type of issues are you having?
I don't think a bad testing is a problem. I think the problem is developers. I don't expect a perfect firmware. Every single software can have bugs. But ASUS creates issues every time they release a new firmware. Why don't they call it Beta? There will not be any problem if ASUS calls their firmware is a Beta.Firmware 45149 works well for the router part and for what the router is intended for: a mix of router, 4-port switch and wireless access point.
I really consider all other shiny features as optional and nice to have, those are usually the ones causing issues.
The next firmware version for sure will fix a few things and break things that have worked for long time, that is the life cycle of firmware.
For those who believe it is a matter of "bad testing by ASUS", I would dare you to develop software and do "good" testing: you will end up by never issue a new firmware release.
For every user reporting an issue, there are typically 10 more who have no issues at all. A lot of people reporting issues also fail to do any real troubleshooting - issues are often within their network rather than with the router itself.
Just flash it, and test for yourself. Every firmware release will always have its share of people reporting "issues".
Flashing is fine. For me? I have to recreate all of own settings such as block lists, static devices and more. It kills me.
Someone who is using only basic features is just fine with any firmware though.
Firmware upgrades do not affect existing settings. There is no need to reconfigure after an upgrade.
Wrong. Routers are security devices, they are the first (and often last) line of defense between the open Internet and your LAN. Security issues are discovered and fixed all the times by these upgrades. Failing to keeping up to date means you are at risk of having your router compromised, potentially turning it into a zombie remotely controlled by a malicious entity who can then use it (along with hundred of thousands of infected devices) to launch attacks on websites.
In short: users and manufacturers) failing to keep their routers (and other connected devices) up-to-date are part of the problem. Compromised devices are used to launch DDoS attacks on servers, or to spread their malware to other unsecure devices. Just two of the most recent examples:
https://badpackets.net/200000-mikro...-compromised-to-inject-cryptojacking-malware/
https://blogs.akamai.com/sitr/2018/11/upnproxy-eternalsilence.html
I don't think so. Up-to-date firmware can't prevent hacking 100%. It helps but not 100%.All of these devices wouldn't be compromised if they were running up-to-date firmware.
Telling people to avoid upgrading if "everything works fine" or "my needs are simple" is just bad advice from a security point of view.
agreed that's why i;m nervous wiyh 6 month old FW on my 3200'sFirmware upgrades do not affect existing settings. There is no need to reconfigure after an upgrade.
Hi Follower,I know it doesn't affect existing settings. But sometimes we have to clear NVRAM. NVRAM clear deletes everything.
Hi Follower,
I have a habit of doing Factory reset for my AiMesh Router / Nodes for each new Firmware Upgrade. Amongst other things I have 40 device IPs to manually set for my DHCP. It is very time consuming and boring to do by hand each time. I am lazy and this is how I do it in a post about 6 months ago:
https://www.snbforums.com/threads/a...le-3-0-0-4-384_20648.46476/page-2#post-404706
If you search this forum, there are a couple of ways to save and restore selected NVRAM settings.
Follower,Hi Lim!
lol
You have a same habit like me! I've tried some scripts. But it didn't work that good enough. I also used to play with some tools such as Putty or winSCP for it. After then I do it manually...It kills me though.
Welcome To SNBForums
