aex.perez
My setup is pretty much stable, took me a bit to get the WiFi just right, but I suspect that's going to be the same regardless. Also pretty much hands off right now, unless something goes south, Police helicopter fly bys, or someone brings up their system using a similar channel for example. Fortunately I'm in a WiFi sweet spot, with few neighbors and being far enough from interference that my WiFi is VERY stable. A main plus, what I'm liking is not having to use a Router ($$$) as a node, when an AP will do the job.It's actually more user-friendly than Asuswrt-Merlin + AMTM + Scripts. What is listed in your signature is built-in plus much more, including live data on your screen. I know you like monitoring things and you'll probably be watching it as entertainment for hours. No NAT acceleration hacks, no 3rd party involvement. The little box does everything in house with very quick UI.
Logs per category:
Radios:
Insight:
Client list options:
If/when I jump on WiFi 7 or AT&T delivers more than 1Gb to me, then I'll have to make some decisions. Right now though life is good, and since I'm not and will never use some of the more questionable features , which could speed the process up if I got hacked, I'm good so far. One thing for sure implementing PoE, Security cameras (currently WiFi, but prefer wired) and a NVR would be a easier, that's for sure. Some other things I'm seeing are things I've looked at but worked around or done without. Having been on this setup for a couple of years, and a two AC5300's before that, been with this tech for a bit and on Merlin slightly longer.
5Ghz/160Mhz, I regularly (regardless of Speedtest Server) achieve +/- 650Mb over WiFi on the iPhone (AX-2x/80Mhz) and Laptop (AX-2x/160Mhz) which is plenty. 2.4Ghz/40Mhz (I know I'm selfish) and the (AX-1x/40Mhz) cheap Andrioid Tablets achieve +/- 200Mb (they don't have 5Ghz cheap). Not bad, based on many of the posts I seen here. Even if I upgraded the switching to enable 2.5GB, that 1GB out the Internet remains a limiting factor.
I got time as nothing is forcing my hand, but I'm really like what I'm seeing
