(Static IP) WAN issue, little to no throughput
iotzan
Hello everyone,
I've been trying to get my new router to work for almost a week now. Being out of options, I thought I might bother you for some help.
The router came with firmware 3.0.0.4.260.
My WAN is set up as Static IP with 2 ISP-provided DNS servers entered manually. I also provide a MAC address for the WAN interface. During the quick set up steps, I also configured the wireless with different SSIDs and WPA2-Personal authentication.
Setup ended with one wired desktop, one wireless laptop and one smartphone connected in the LAN.
Internet access is almost nonexistent at this point. I mean, I see a few KB of traffic in a couple of spikes across 1-3 minutes.
Following are a few network tests that I made:
GW #1
Ping statistics for XX.XXX.250.1:
    Packets: Sent = 200, Received = 151, Lost = 49 (24% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 28ms, Average = 2ms
GW #2
Ping statistics for XX.XXX.92.1:
    Packets: Sent = 200, Received = 144, Lost = 56 (28% loss),
    Minimum = 0ms, Maximum = 9ms, Average = 2ms
DNS #1
Ping statistics for XX.XX.65.5:
    Packets: Sent = 200, Received = 154, Lost = 46 (23% loss),
    Minimum = 0ms, Maximum = 2ms, Average = 0ms
DNS #2
Ping statistics for XX.XX.65.9:
    Packets: Sent = 200, Received = 149, Lost = 51 (25% loss),
    Minimum = 0ms, Maximum = 3ms, Average = 0ms
DNS #3
Ping statistics for XXX.XXX..128.1:
    Packets: Sent = 200, Received = 153, Lost = 47 (23% loss),
    Minimum = 1ms, Maximum = 3ms, Average = 1ms
Tracing route to forums.smallnetbuilder.com [216.14.113.203]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  www.asusnetwork.net [192.168.1.1]
  2     5 ms     1 ms     2 ms  gw.XX.XXX.250.1.xxxxxx.ro [XX.XXX.250.1]
  3     1 ms     2 ms     *     XX.XX.65.9
  4     *       <1 ms     1 ms  XX.XX.65.11
  5     1 ms    <1 ms     *     46.19.104.221
  6    13 ms    13 ms    13 ms  as56654.bar1.Budapest1.Level3.net [212.162.26.45]
  7     *       29 ms    29 ms  4.69.141.250
  8     *       29 ms    29 ms  ae-63-63.csw1.Frankfurt1.Level3.net [4.69.163.2]
  9     *        *        *     Request timed out.
 10     *       30 ms    30 ms  xe-0-2-0.mpr1.fra4.de.above.net [64.125.14.5]
 11    39 ms    39 ms    39 ms  xe-0-1-0.mpr2.cdg12.fr.above.net [64.125.24.94]
 12     *        *        *     Request timed out.
 13     *       47 ms     *     xe-2-0-0.mpr2.lhr3.uk.above.net [64.125.28.93]
 14    46 ms     *        *     xe-0-0-1.mpr3.lhr3.uk.above.net [64.125.21.17]
 15     *      137 ms     *     ge-3-3-0.mpr1.la5.us.above.net [64.125.26.37]
 16     *        *        *     Request timed out.
 17   141 ms   141 ms     *     xe-0-2-0.cr2.ord2.us.above.net [64.125.27.33]
 18     *      136 ms   137 ms  xe-0-1-0.mpr2.ord6.us.above.net [64.125.31.201]
 19     *      148 ms   148 ms  64.125.192.146.t00718-01.above.net [64.125.192.146]
 20     *      137 ms     *     69.8.117.130
 21   137 ms   137 ms   137 ms  oak01-mls-dc-dist-a.stargate.com [69.8.117.22]
 22   136 ms     *      136 ms  69.8.118.150
 23     *      137 ms   136 ms  216.14.113.203
  1    <1 ms    <1 ms     1 ms  www.asusnetwork.net [192.168.1.1]
  2    <1 ms     2 ms     2 ms  gw.XX.XXX.250.1.xxxxxx.ro [XX.XXX.250.1]
  3    <1 ms    <1 ms    <1 ms  XX.XXX.65.9
  4    <1 ms    <1 ms    <1 ms  XX.XXX.65.11
  5     *        *        *     Request timed out.
  6    14 ms    13 ms     *     as56654.bar1.Budapest1.Level3.net [212.162.26.45]
  7    29 ms     *        *     4.69.141.250
  8  1042 ms     *       29 ms  ae-63-63.csw1.Frankfurt1.Level3.net [4.69.163.2]
  9     *        *       29 ms  ae-1-60.edge5.Frankfurt1.Level3.net [4.69.154.9]
 10     *       81 ms    30 ms  xe-0-2-0.mpr1.fra4.de.above.net [64.125.14.5]
 11     *       67 ms     *     64.125.24.94
 12    46 ms    46 ms     *     64.125.24.81
 13    53 ms    58 ms    46 ms  64.125.27.154
 14    46 ms    46 ms     *     64.125.24.121
 15     *      118 ms     *     ge-3-3-0.mpr1.la5.us.above.net [64.125.26.37]
 16   110 ms     *      111 ms  xe-1-0-0.cr2.lga5.us.above.net [64.125.29.46]
 17   157 ms   141 ms     *     64.125.27.33
 18   137 ms   138 ms   137 ms  xe-0-1-0.mpr2.ord6.us.above.net [64.125.31.201]
 19   148 ms   175 ms   148 ms  64.125.192.146.t00718-01.above.net [64.125.192.146]
 20     *        *        *     Request timed out.
 21   137 ms     *        *     oak01-mls-dc-dist-a.stargate.com [69.8.117.22]
 22   135 ms   135 ms   136 ms  69.8.118.150
 23     *        *      138 ms  216.14.113.203
By comparison, this is the same connection, tested from my desktop. Only device in between being a CISCO SE2800 switch.
GW #1
    Packets: Sent = 200, Received = 194, Lost = 6 (3% loss),
    Minimum = 0ms, Maximum = 10ms, Average = 1ms
GW #2
    Packets: Sent = 200, Received = 195, Lost = 5 (2% loss),
    Minimum = 0ms, Maximum = 16ms, Average = 2ms
DNS #1
    Packets: Sent = 200, Received = 197, Lost = 3 (1% loss),
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
DNS #2
DNS #3
Ping statistics for XXX.XXX.128.1:
    Packets: Sent = 200, Received = 192, Lost = 8 (4% loss),
    Minimum = 1ms, Maximum = 2ms, Average = 1ms
  1     2 ms     5 ms     2 ms  gw.XX.XXX.250.1.xxxxxx.ro [XX.XXX.250.1]
  2    <1 ms    <1 ms    <1 ms  XX.XX.65.9
  3    <1 ms    <1 ms    <1 ms  XX.XX.65.11
  4     1 ms    <1 ms    <1 ms  46.19.104.221
  5    13 ms    13 ms    13 ms  as56654.bar1.Budapest1.Level3.net [212.162.26.45]
  6    29 ms    29 ms     *     4.69.141.250
  7    29 ms    29 ms    29 ms  ae-63-63.csw1.Frankfurt1.Level3.net [4.69.163.2]
  8    29 ms     *       29 ms  ae-1-60.edge5.Frankfurt1.Level3.net [4.69.154.9]
  9    30 ms    30 ms    30 ms  xe-0-2-0.mpr1.fra4.de.above.net [64.125.14.5]
 10    84 ms    87 ms    87 ms  xe-0-1-0.mpr2.cdg12.fr.above.net [64.125.24.94]
 11    46 ms     *       46 ms  xe-5-2-0.mpr1.lhr3.uk.above.net [64.125.24.81]
 12    45 ms    46 ms     *     xe-4-0-0.mpr2.lhr3.uk.above.net [64.125.27.154]
 13     *       46 ms     *     xe-0-1-1.mpr3.lhr3.uk.above.net [64.125.21.21]
 14   122 ms   118 ms   118 ms  ge-3-3-0.mpr1.la5.us.above.net [64.125.26.37]
 15   109 ms   110 ms   125 ms  xe-4-3-0.cr2.lga5.us.above.net [64.125.22.170]
 16   141 ms   163 ms   161 ms  xe-0-2-0.cr2.ord2.us.above.net [64.125.27.33]
 17   136 ms   137 ms   136 ms  xe-0-1-0.mpr2.ord6.us.above.net [64.125.31.201]
 18   148 ms   147 ms   148 ms  64.125.192.146.t00718-01.above.net [64.125.192.146]
 19   137 ms   137 ms   137 ms  69.8.117.130
 20   137 ms   176 ms   137 ms  oak01-mls-dc-dist-a.stargate.com [69.8.117.22]
 21   135 ms   135 ms   135 ms  69.8.118.150
 22   136 ms   136 ms   136 ms  216.14.113.203
Any ideas anyone?
Regards,
Iotzan
Have you also entered proper gateway information for your WAN connection?
Have you tried differnet DNS servers?
I have tried with the 2 GWs listed in my test results and also with Google's DNS servers in addition to the 3 DNS servers of my ISP.
I did read something around here, which I also tried. I set my router, 192.168.1.1 as DNS server in the LAN - DHCP server page. This results in getting some traffic through sometimes, though pages never finish loading.
And if you connect a computer directly to your modem, everything works fine, correct?
No. If I reset to original settings and go through the set up again, from my PC or laptop exclusively, the same issue manifests.
EDIT:
I have tried a lot of different configuration options. I am reluctant to post them so as to not focus anyone on a potential wrong issue. I am however, open to any ideas even if it means retesting something on my side.
And also, many thanks for replying on a late Sunday :)
If you took the router out of the loop, the problem is with your ISP connection. Contact their tech support.
I'm sorry, I don't follow. My ISP provides a Cat5e. I can use that either directly or put a router in between.
I only have problems when I'm using the router.
It works perfectly when using the link directly or through a switch. I was previously using a D-Link DIR-600 and had no issues.
When I said "modem" I mean broadband modem, not router.
Have you tried adjusting MTU (if the static WAN settings allow you to)?
Hello everyone,
Hi Iotzan,
I am running static WAN configuration (for security reasons) for years and this is by sure not the reason for the issues you have. :rolleyes:
First of all I would update to the latest firmware from Asus directly, or - even better from Merlin!
You are two releases behind the actual version... :eek:
Especially the latest version .354 improved the LAN/WLAN performance and stability due to new hardware drivers in the router!
Then I would suggest to reset the router to factory defaults and start fresh configuring it.
Do it step by step (just WAN first - checking), then WLAN (checking), etc.
With kind regards
Joe :cool:
I would try to change the MTU, but I can't seem to find it in RT-N66Us settings.
You can change the MTU/MRU in the web interface only if you run a PPPoE WAN configuration!
From router telnet session you could do
ifconfig eth0 mtu xxxx
But I would try my suggestion from above... :rolleyes:
With kind regards
Joe :cool:
B Issue with wired clients on ASUS N56U ASUS N Routers & Adapters 0
